![]() Join Date: Mar 2007
S13 rolling chassis!! **SHELL READY TO GO!!!
MY ASKING PRICE FOR THE SHELL AND ALL MY PARTS IS $1300 OBO
I have my 1990 s13 HATCH rolling shell! It's a Se model! clean title and tags are good till the end of this month! Its maroon with a flat black painted front end, It has some driver side rear quater panel dents nothing huge but its there, The door was also pretty beat but I just replaced the door with a CLEAN door. It has COMPLETE interior and the DASH ISNT CRACKED AT ALL!! CLEAN BLACK DASH. All the interior panels are black. now for what the car comes with and what it has on it. CLEAN TITLE!!!!!! ALL ELECTRONICS WORK !! REAR WIPER! HEADLIGHTS, BRAKE LIGHTS,SIDE LIGHTS, DEFROSTER EVERYTHING. PRICE IS MAKE AN OFFER! DON'T LOW BALL ME ALL CRAZY I SEE BUSTED ASS SHELLS WITH NOTHING SELLING FOR $500-800. IM INCLUDING ALOT OF PARTS TO MAKE THE CAR FLAWLESS ALL IT WOULD NEED IS YOUR RIMS AND COILOVERS. It's a 5 speed original shell I'll be including the following! Battery is relocated to the trunk with a custom batter mount, 0 gauge wire for positive and 2 gauge wire in the back with 10 gauge wire running up front split into 4 lines for more engine grounding Sr20 tranny and drive shaft still bolted on the car! B-magic 25mm rear wide body over fenders (to cover up the dents it has on the drive side) Complete un-cut Lower harness re done, It has a welded diff already installed, Tanabe shocks and struts with lowering springs S14 seat belts driver and passanger S14 passanger seat Single cam gauge cluster with a complete dual cam rpm sending unit swapped in (it reads 115 mph instead of the dual cam cluster 110 mph) After market steering wheel with hub 2 chuki front bumpers one with lip one without lip A whole other complete subframe with diff,axels,all control arms with good non ripped bushings (came off a chassis with 49k miles!!) Front nismo extended studs Circuit sport 4 and 5 lug rotors with bfg ss teflon coated brake lines for z brake set up (all you need the some z calipers and you have a z brake setup) Extra passanger side door (doesnt need one just had two doors laying around) FUll complete brand new Energy suspension master bushing kit for the s13 chassis car will be rolling on 4 after market 17 inch wheels, two 5 zigen 17x8 and two other mixed rims but are both 17x8 with tires. Sr20det power steering pump Megan tension rods Walbro 255 lph already wired in the tank (your more than welcome to pull the hanger and check the pump if you are buying with cash in hand) BASICALLY ALL THIS CAR NEEDS IS AN ENGINE AND SUSPENSION AND YOUR READY TO GO!! EVERYTHING WORKS AND IS READY TO GO! THE BATTERY IS HOOKED UP SO YOU CAN SEE EVERYTHING WORKS AND ALL THAT! YOU CAN CALL ME OR TEXT ME AT 626 808-3725 MORE INFO. IM SURE THERE IS MORE PARTS THAT I'M FORGETTING TO ADD IN THERE! PICS TOMORROW WHEN I GET TO MY SHOP
Obliterate Last edited by rb25_s13*CHUKI; 01-05-2012 at 04:52 AM.. |
