Boost not holding...
Here's the mod list...
1990 240SX Fastback SR20DET Redtop HKS Type S FMIC HKS SSQV BOV Heavy Throttle Hotpipe Blitz Nurspec Exhaust Blitz 3" Downpipe JGY Customs 3" Testpipe ACT Street/Strip Clutch Walbro 255LPH Fuel Pump Turbo XS MBC When I floor it, the car will hit like 12psi in first gear, then, when I shift into 2nd it will hold 8psi, then the shift to third and it holds 5psi all the way through that gear... WTF? |
Check vacuum lines, see if there is any losen one. At what point do you hear you wastegate? I had the same problem but reverse. I had no boost at low gears and a lot of it at 3rd-5th, more than i expected. It turned out that my wastegate needed to be overhaul.
