1JZ-GTE part out (2 engines) *Okinawa
All parts located in Okinawa Will ship at buyers expenses Cylinder block(s) and transmission will not be shipped Cylinder head(s) will only be shipped in small gorilla case (case included in price) All Prices OBO Payment- unless local, PayPal only Shipping note- Although the parts are located in Okinawa, USPS is how I will be shipping the items, so don't freak out, it's similar to shipping from CA. I was going to do a 1j swap in my Corona but I've decided to stick with the original plan. I'm also PCSing soon so I need to get rid of these. Both engines are twin turbo, non-VVTI One engine is out of a JZX81, the other is from a JZX90 Both were running when pulled Both have been sitting for almost a year. Both engines have some surface rust from not being in a climate controlled area, so they could use some cleaning. JZX81 Engine Info- Running when pulled ~Feb 2011 Bottom end rebuild late 2010 Can't remember the mileage on the head... Was connected to a W58 (5spd) JZX90 Engine Info- Running when pulled (same time) Had an issue, after idling for a few minutes it would sputter and shut off then after a few minutes, start it up and it would run fine. Never got to trouble shoot it before it was pulled, it was intended to be spare parts. Was connected to automatic trans. Had ~110k km iirc If you happen to be in Okinawa, you can pick up everything I have for $1000 OBO. (both engines, W58 trans, downpipe, jzx81diff + axles...all of it) Parts- Valve covers (2 sets, one set painted) $60/ea Intake Manifold (2) $100/ea Light weight pulleys (1 set-4 pulleys) $100 Turbo set with piping (1 with new seals/gaskets) $150/ea Alternator $40 PS pump $40 Water Pump (clutch fan type, installed when bottom end was rebuilt) $90 Clutch fan $30 Clutch disk, Flywheel, new pressure plate (push type, disk used but plenty of life) $100 Cylinder Head +Case (with cams, no manifolds/covers) $200/ea Front sump oil pan set $100/ea JZX81 FMIC $100 JZX81 clutch pedal, cmc, slave, ss line $100 7m Injectors $50 Sold Items- JZX81 Harness $150 JZX81 5spd ECU $200 Coil pack cover + Timing cover (1 sold) Any other items, just ask/offer. I'd like to get some offers on everything before I start pulling them apart Pics... I'll get more up later, and possibly more parts. ![]() ![]()
