![]() Join Date: Dec 2004
Trader Rating: (58)
A/C Air Conditioning kits for SR20 swaps! Adapt any KA compressor setup to an SR20!
AC Air Conditioning Conversion kits for SR20 Owners! Adapt any KA compressor setup to any SR20!
http://www.sr20acbrackets.com http://www.sr20acbrackets.com http://www.sr20acbrackets.com Arguably one of the biggest issues/pet peeves with the SR20 swap in USDM S chassis cars it the lack of working AC in them. This has always been an issue due to line differences , compressors being seized, and lack of AC shops to make an affordable solution. A few years back I solved this issue by making conversion brackets that allow owners to bolt their DOHC KA compressors to any type of SR20 engine. Now, 4 variants later, I’m on version 4.0 of my kits, finally offering clearance for ALL oil pans (Greddy/Moroso/Tomei/Circuit Sports) and all sway bar combinations that I could get my hands on for both chassis. How does it work As stated above, the kits allow any KA compressor to be bolted to any SR20 type; they are completely interchangeable so long as you know the compressor type, and SR bracket type. Essentially, you could use an S13KA compressor in an S14 car, and you can use a redtop bracket kit on a blacktop engine…no more worries about getting the right stuff, as it all works! Pulley and belt line up works the same regardless. Kit Contents: Literally Everything! All of the needed hardware to secure the adapter brackets to the SR bracket, and new hardware to secure the compressor to my adapters brackets. My kits also come with the correct belt for the application (so long as using OEM crank pulley, if using aftermarket you can purchase kits without belt, please Contact Us) New Features The new version 4.0 brackets offer a new thinner profile, thanks to utilizing flat head allen bolts to secure the adapters to the SR bracket. The Flat head allen bolts also allowed the compressor to be moved up nearly ¾ of an inch finally giving clearance to the Moroso pan owners. Lastly, the Flat head allen bolts self-center the brackets, meaning no misalignment issues! ![]() ![]() ![]() http://www.sr20acbrackets.com http://www.sr20acbrackets.com http://www.sr20acbrackets.com To Determine What Kit you have: ![]() Pricing: S13 KA compressor to SR20 Redtop or S15 SR20: 70 shipped S13 KA compressor to S13/S14 SR20 Blacktop: 110 shipped S14 KA compressor to SR20 Redtop or S15 SR20: 110 shipped S14 KA compressor to S13/S14 SR20 Blacktop: 110 shipped Purchasing For purchasing information, please check out my website at CodyAce SR20 Air Conditioning Bracket or PM me Contact me for any other information or questions you may have: If you have any other questions feel free to email me at any time (codyace AT gmail DOT com) or PM me. http://www.sr20acbrackets.com http://www.sr20acbrackets.com http://www.sr20acbrackets.com
![]() Join Date: Nov 2008
This is a must do step when your doing a sr swap on your car. If your installing with your compressor in the bay, put the top bolt in the compressor before you put the motor in. Makes everything a bajillion times easier!
#3 | |
Trader Rating: (58)
#8 |
![]() Join Date: Jun 2003
Trader Rating: (130)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 130 reviews
Sent payment this afternoon. Looking forward to getting it in the mail. (then I'll be all out of excuses to start my engine swap)
#9 |
![]() Join Date: Dec 2008
Trader Rating: (79)
![]() Feedback Score: 79 reviews
do you sell R12 as well lol
My Build: The "Coupe De Ville" 1JZ Build!! |
#11 |
Trader Rating: (58)
I didn't realize the post office would be closed for Martin Luther King Jr. Day, so all kits will now be going out tomorrow!
#12 | ||
Trader Rating: (58)
If you do not have an SR20 AC Tensioner bracket, you can use anyone, from any year (as they all bolt to the block in the same fashion)...but you'll need to confirm which bracket you have with my picture to make sure you get the correct kit ![]() With that all said I'd assume you will need teh S14 to S14 Blacktop kit, but you know what they say about assuming ![]() Thanks brother! Haha, Not anymore. Too expensive. It's proven to work really well converting systems over to R134a, so that's always an option as well.
#16 |
Trader Rating: (58)
I actually don't...but there are quite a few s13 part out sin the classifieds, may be worth a shot? Hard to say if they still have them though
#17 |
This may be a stupid question, but searching around didn't answer it fully.
If my car was originally SOHC but now SR, I can't retain the old lines or condenser? I have to pretty much swap out the whole setup for a DOHC one? Then get your bracket? Thanks |
#18 |
Trader Rating: (58)
I've personally never done the SOHC to DOHC part swap, but have had many who have with success. With that said, you are going to need a DOHC compressor, and the lines that go from the firewall to the compressor, and the compressor to the condenser at a minimum. Aside from that, I've had some customers say it worked, and had other say they also needed to change to a DOHC condenser.
#19 |
Edit: what happened is my s13 came with an s14 style compressor, so I had ordered the wrong kit. Upon comparing your photo with my compressor it's clear to see the difference.
Thanks for the quick reply via email and the excellent support!!! Last edited by brndck; 02-11-2012 at 08:47 AM.. |
#20 |
Trader Rating: (58)
Your correct kit will be headed out today Tyler! Thanks for being patient with this all and working with me to get it sorted out! It's certainly a confusing thing, as some later model s13 did come with the square pattern compressors.
Kits are still in stock guys, and can ship same day or next day!
#22 |
Quick update. I did rec
#23 |
Quick update. I did receive the new kit and it bolted up perfectly. Hardware was real nice and the quality is excellent. Thanks a ton man!!!
#24 |
s14 kit
i have a s14 bolt up kit for a sr20det s14 swap and it says U for upper L for lower? well when i put the long bolts through the compressor to ur new bracket, it clears but the fits barely, im not sure what version i have but the bolts are too short, the brackets are not like the new version, mine has two cylinder ish things welded to the plate, do you have any specific pictures of this old version hooked up, im pretty sure i have the right kit, my sr bracket is is in the shape of a square not the uneven square version, any help will b appreciated, thanks.
#28 |
yeah they also come with lines and freeon
240 with illegal engine mod. |
#30 |
![]() Join Date: Oct 2010
wow... this makes me wanna buy an AC compressor right away!!! my gf hates my fkn car because of it lol ..im at NOOB at Ac stuff.. all i'd really need is to buy an s13 compressor? and the belt? i have a blacktop s13 Sr20..
