Old 01-20-2012, 04:05 PM   #1
240zach
240zach's Avatar
240zach is an unknown quantity at this point
Thumbs down s14 diff bolt help!!!
so recently i put in a welded diff, but taking out the old diff was a pain, and heres what happened,
the left bolt that held in the bushing and bolted to the subframe had been stripped and it just spun in place and i had no time so i had to cut the head off the bolt, so now ive got a stripped bolt with no head stuck inside there and idk how to remove it.
can someone please point me in the right direction or help me on this cause idk what i can do to get this thing out. id like to be able to run both bushings instead of one on my diff. thanks
240zach is offline   Reply With Quote
Old 01-20-2012, 04:59 PM   #2
Sileighty_85
Sileighty_85's Avatar
I can think of three ways
1) Big vise grips- clamp on it hang on it and turn
2) weld a bar on the bottom end to make it look like a an upside down "T"
Pull and twist
EDIT:
3) cut off flush, drill out and re-tap threads
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-20-2012, 07:22 PM   #3
Tokona-x
Tokona-x's Avatar
Trader Rating: (140)
Tokona-x is an unknown quantity at this point
Feedback Score: 140 reviews
Send a message via Yahoo to Tokona-x
+ 1 for vise grips or the T handle ...if you can get a hold of a small blow torch I would heat the part of the bolt where it screws in that should help it out too, O and if it's a little rusty spray some PB blaster on it that stuffs awsome! Good luck man!!
I have five speed bolts if you need any
Custom 2+2 E brake Cable brackets sold here!!!!!
Tokona-x is offline   Reply With Quote
Old 01-20-2012, 08:03 PM   #4
240zach
240zach's Avatar
its not rusty its just a bitch to get to...i might have to do the vise grips and pray that ill have enough force pulling down on it..lol
Old 01-20-2012, 09:25 PM   #5
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
or you can go to a muffler shop and have them weld a nut at the end and use the correct size wrench/socket to take it out. done this a few times with broken exhaust studs.
rcdad123 is offline   Reply With Quote
Old 01-20-2012, 10:18 PM   #6
240zach
240zach's Avatar
^ even if its stripped?
Old 01-23-2012, 01:35 AM   #7
240zach
240zach's Avatar
Anymore suggestions? Anyone?
Old 02-22-2012, 02:21 AM   #8
240zach
240zach's Avatar
bumppp need help with this, lol
s14, subframe, welded diff
