Old 01-26-2012, 10:18 AM   #1
DaveAZ
DaveAZ is an unknown quantity at this point
What diff do we have?
Rear off the ground in N, both wheels spin the same way, put in gear, one turns one way, one turns the other. (VLSD?)
Ratio looks to be something near 3.2 to 1. No where near the 4 to 1 of the J30 or 240. (Previous owner said it was J30)
Has six hole axle, no ABS ring. About 11 inches long excluding rear cover. Nearest I can figure is a Pathfinder diff??
Axle seal leaks, and it whines LOUD. This is a DD car, so we'd like to get the right parts before removing it and rebuilding it. Thanks in advance.
DaveAZ is offline   Reply With Quote
Old 01-26-2012, 12:30 PM   #2
s13 jarrod
s13 jarrod is an unknown quantity at this point
To me it sounds like you got a welded diff bud.
s13 jarrod is offline   Reply With Quote
Old 01-26-2012, 12:53 PM   #3
Darren
Darren's Avatar
Darren is an unknown quantity at this point
Do the tires chatter in parking lots... if so, you may indeed have a welded diff..
To me, it doesn't look any different than a standard r200 diff...
Darren is offline   Reply With Quote
Old 01-26-2012, 12:57 PM   #4
JDM_Tuner
JDM_Tuner's Avatar
JDM_Tuner is an unknown quantity at this point
that means its an open diff, so really it doesnt matter what type of diff it is, since its an open diff you might as well just upgrade.
JDM_Tuner is offline   Reply With Quote
Old 01-26-2012, 02:10 PM   #5
DaveAZ
Thanks everyone for the comments. Looks like everyone agrees. I'd been researching these diffs, and found so much contradictory info, so I posted here.
I guess my son and I are in the market for a J30- 95-96 diff? I'm not funding a Kaaz setup or anything.
Thanks again. DaveAZ
Old 01-26-2012, 02:18 PM   #6
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
i had vlsd in my car before and after a track event i noticed it started whining. and when i went home from the track it got louder and louder to a point it hurt my brain to continue driving so i had to call a tow truck and haul it the rest of the way home. i think they said one of the bearings went bad or something. just ended up taking it out and putting a 2way cusco.
rebornS14 is offline   Reply With Quote
Old 01-26-2012, 02:28 PM   #7
s13 jarrod
Well as long as it's not welded it will be fine to daily drive on, I mean even if it is you can still drive on it just eats the hell out of your tires and is real fun in the rain! But they are fine mine has been welded for the last 3 years.
Old 01-26-2012, 05:52 PM   #8
DaveAZ
I was hoping for some explanation why it's geared so much higher than a stock 240. It's just a tad over 3:1.
Old 01-26-2012, 05:57 PM   #9
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
Pop the cover off and take a peek at the stamp on the ring gear. That'll tell you exactly what the ratio is, and where it's from.
-Kyle
Old 01-27-2012, 05:56 AM   #10
DaveAZ
Yep. Was trying to avoid that without having the parts, or a new diff to put in. (Daily Driver)
Once we drop it and open, I'll post what I find.
Old 02-03-2012, 07:15 PM   #11
DaveAZ
I said I'd post what I found. Here it is. Looks like a VLSD to me. The case was definately S13- small front mount holes, and shorter length. It's thrashed, but the J30 we just put in, (internals identical) is way quiter, and though it's .5 inches longer with the ABS ring, the drive line fit fine.
Old 02-25-2012, 10:09 AM   #12
Vikter138
Vikter138 is an unknown quantity at this point
You have a picture of your new diff?
Vikter138 is offline   Reply With Quote
Old 02-25-2012, 10:34 AM   #13
DaveAZ
No, but it is exactly like the other J30 VLSD you see photos off. Has the ABS ring, the larger front mounting holes, and the six-hole axles., noticably higher gearing.
Very unlike the one we pulled, which you never see photos of, or even hear about....or at least I hadn't. It was very much looking like stock S13. But it was definitely VLSD and the previous owner pulled it himself. Gearing was lower as well.
Old 02-28-2012, 08:07 PM   #14
cmg
cmg is an unknown quantity at this point
Whats the possibility it was an r32 diff or something? Im unsure if they are the same or not but they are both r200..
cmg is offline   Reply With Quote
