Old 01-11-2004, 11:24 AM   #1
chooselife
chooselife is an unknown quantity at this point
Z32 front brake conversion
Hello from France,
I'm new on Zilvia.net forum. I drive stock '94 200SX S14 with SR20DET engine. I'm engineer in automotive gearbox design.
My tech question is about Z32 brake conversion on a 200SX S14 car. My front brakes are 280x30mm discs with 4 pistons callipers (iron or aluminium, I don't know). What is the improvement to put Z32 brakes, which are, if I'm right, 280x30mm discs with 4 pistons callipers, so same dimension ?
More pads surface ? more large calliper piston diameter ?
chooselife is offline   Reply With Quote
Old 01-11-2004, 11:38 AM   #2
chooselife
I've got my brake measurement
Cylinder bore diameter : 40,4 mm x 2
Pad length x width x tickness : 116 x 50 x 10 mm
If you've got the 300ZX brake information, thanks ...
Old 01-11-2004, 12:19 PM   #3
DSC
New Title
DSC is an unknown quantity at this point
Here in the US we have 1 piston sliding calipers, with some pretty small rotors so the 300zx brakes are a big upgrade. I'm not sure what the differences are between the 300zx brakes and france 200sx brakes.
DSC is offline   Reply With Quote
Old 01-11-2004, 12:35 PM   #4
BuudWeizErr
BuudWeizErr's Avatar
BuudWeizErr is an unknown quantity at this point
Send a message via AIM to BuudWeizErr
If your S14 is like the Japanese S14 K's, your front brake calipers are almost, if not the exact same as Z32 brakes.
I wouldn't bother doing a Z32 brake upgrade on your car, it probably won't make any difference.
Only in the US would we need them, since all the S-chassis got the shaft for brakes (and everything in general).
1989 Nissan 240SX, SR20DET
sillbeer.COM : phase2motortrend : Garage Works
BuudWeizErr is offline   Reply With Quote
Old 01-13-2004, 05:39 AM   #5
speeddreamz
speeddreamz's Avatar
speeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nice
Send a message via AIM to speeddreamz
only the s13's and 180s which came with hardly bigger rotors did not have Z brakes. The s14, s15's all had z brake upgrades in japan and australia or anywhere it has an sr20det. The skyline r33's in gtr or is it gt-s are brake upgrades. otherwise invest in like a project mu 6 piston brake (3 on each side) or some good brake pads...like project mu or some other popular brands.
speeddreamz is offline   Reply With Quote
Old 01-13-2004, 09:20 AM   #6
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
If you want bigger than you have now, look into 300zx brake upgrades. Not 240sx or 200sx brake upgrades. There are some decent upgrades that just use larger rotors, which generally make a pretty nice improvement.
Quick question.. what size is your Master Cylinder?
sykikchimp is offline   Reply With Quote
Old 01-14-2004, 01:43 PM   #7
chooselife
Hello,
My master cylinder is different than the Z32 : diameter 25.4mm. The other differences are the brake booster and the rear brake piston diameter.
About Skyline R-33 brake rotor needs 17" wheels (I've got standard at 16", so doesn't fit).
I think for the first step : Good brake pads like Ferodo DS 2500 + stainless braide hoses. And perhaps better rotor, treatment, grooved.
I know there is brake upgrade kit, with larger rotor, and bracket to mount them with the standard calliper. 310 mm is the maximum in standard wheel, see on www.apex-performance.co.uk.
Old 01-14-2004, 01:55 PM   #8
sykikchimp
WOW addicted
sykikchimp's Avatar
Is this a Street brake upgrade, or for track use?
Ferodo pads are awesome.
Old 01-14-2004, 11:36 PM   #9
chooselife
Street use, and occasionnal track.
I must change my brake pads (Front and Rear), I will use this maintenance to upgrade my brake.
Old 01-15-2004, 12:35 AM   #10
thx247
thx247 is an unknown quantity at this point
with a rotor that size, you can probably get away with a track pad and decent fluid.
thx247 is offline   Reply With Quote
