Old 02-11-2012, 02:42 PM   #1
Anon9mouz
Anon9mouz's Avatar
Anon9mouz is an unknown quantity at this point
Help on wiring 95 Zenki plz
I just bought a mishimoto aluminum radiator and fan shroud kit and stock only had two wires I think while the new one has more I think. Was looking for a wiring diagram bc Idk if its just two positives and negatives or what im lost so any help would be great thanks
___________________________________________
Sent from my PG86100-EVO3D-using Tapatalk Born Jan 5th 84 and still getting it in eeee
Anon9mouz is offline   Reply With Quote
Old 02-11-2012, 03:10 PM   #2
bvr463
bvr463 is an unknown quantity at this point
a fan is a motor, so polarity on the two wires is all going to depend on which way you want the motor to spin...hope this helps
bvr463 is offline   Reply With Quote
Old 02-11-2012, 03:15 PM   #3
Anon9mouz
Anon9mouz's Avatar
Huh lol well i would like to have a diagram but mishimoto isn't cool enough for that I guess lol
Old 02-11-2012, 05:56 PM   #4
JimmBrooks
JimmBrooks is an unknown quantity at this point
So ... the two wires will be for + and -... One wire is grounded, or attached to your negative terminal on the battery, and one is positive. Now keep in mind I am leaving a bunch of stuff out but that should get your mind working. If your putting in a manual switch, it goes on the positive lead of the fan, if your letting it be set via thermostat it needs to have the thermostat relay in the positive lead in order for your ecu to tell the fan when to click on. What ever you do, do not just wire it up to the + and - on the battery or your have one really neat wind generator always on... hope this helps.
JimmBrooks is offline   Reply With Quote
Old 02-12-2012, 12:32 PM   #5
Anon9mouz
Anon9mouz's Avatar
I need something for dummies I know other people bought this mishimoto aluminum radiator, fan shroud. And thermostat kit. I just need a simple easy way to wire up to where it kicks on when it's supposed to. No switch and no wiring into ignition to where it's on 24/7 I want it like if it came factory. Thanks
Old 02-12-2012, 12:36 PM   #6
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Dude its really easy Google it and I promise you will find a spoon fed step by step on how to wire your new relay and your fans will come on whenever the temp gets to a certain point
Old 02-12-2012, 12:49 PM   #7
JimmBrooks
i agree google it, but i sent you a PM and will help you as much as I can,
Trying to do my best to help the comunity...
but seriously its been said a bajillion times, searching, not just on this board, but everywhere will tend to be your best friend.
Old 02-12-2012, 01:15 PM   #8
JimmBrooks
here it is for anyone else... he ordered an electric fan, didnt come with any thermostat relay or wiring, I SEARCHED and found maybe 15 different posts with how to's, so here it is for anyone else in the same situation,
Let me google that for you
