Old 01-14-2004, 11:12 PM   #1
lbcklik1486
lbcklik1486's Avatar
lbcklik1486 is an unknown quantity at this point
Oil Catch Tank ?'s
What exactly does it do, I think i remember it does something like recirculating the unburned gas mixture back into the combustion chamber iirc?
Also, is there any kind of maintenence on that, ie: ne thing you need to keep cleaning internally or such, not getting one, just curious.
ibnotgettingonesostfu
Your car has 4 more liters, and it's unfair to race because I have a turbo huh?
lbcklik1486 is offline   Reply With Quote
Old 01-14-2004, 11:28 PM   #2
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
It recirculates or just catches oil depending on how you set it up. Powerful turbo engines when at full throttle get blowby and oil comes out of the valve cover. Normal cars have it recirculated into the intake which sucks. This lowers the octane of your gas and can create potential problems especially on a powerful turbo engine at full throttle. The same could be said for NA engines but not to the same extent. Basically, it just makes sure you're not getting oil and oil vapor in your intake air.
Flybert is offline   Reply With Quote
Old 01-14-2004, 11:39 PM   #3
lbcklik1486
Ahhhh, thanks a bunch, yea i figured it had something to do w/ catching oil, but couldn't figure out what you would need it for.
