![]() Join Date: Feb 2011
![]() Feedback Score: 12 reviews
Not starting after rebuild
Rebuilt my head this weekend and my car is not starting. Replace spark plugs, distributer, rotor. Im getting spark at the coil and I know Im getting fuel because its all over the plugs. Initially I thought the distributor was in backwards but when switched around still nothing. The engine will turn over but not start. Any help would be greatly appreciated. Thanks- Chris
Edit: Before pulling the head i had 170 across all four cylinders. Now I have 0? Any ideas?
![]() Join Date: Dec 2008
If the cam timing is right then I'd say you messed up somewhere with your valves. Is it 0 on all four? Your valves might not be seating properly.
1990 Nissan 240SX w/KA24DE - New project 1984 Mazda RX-7 GSL-SE 13B |
#3 | |
![]() UPDATE!!!! This issue is getting more and more confusing. The cams and cam gears seem to be spot on with timing. Today I set crank at tdc by the timing marks on idler pulley and distributor rotor. Upon taking the valve cover off and looking at the cam gears everything seems to be exactly where they should be heres pics. At tdc this is what cam gears look like. I marked the dimples with white out as well as the chain when i pull them thats why its white. ![]() Heres the cam orientation at tdc from exhaust side ![]() I have no clue what to do next :/
#7 |
Yeah it was at tdc set it by timing mark on idler pulley and verified at dist rotor before pulling it out. Ive done this several times before which is why i'm so stumped.
#11 |
Theres one major thing that i have no idea how I looked over but I didnt set valve lash :/ (Member on ka-t.org suggested that) Thats the first thing Im goin to do tomorow and Ill report back with what Ive found.
#12 |
![]() Join Date: Aug 2009
Trader Rating: (55)
![]() Feedback Score: 55 reviews
wow I'm having the same issue I'm doing a compression and leak down test tomorrow, if all goes bad I'm throwing this ka away just gonna go sr again
#14 |
It's definitely valves. The timing wouldn't affect the compression that much. If it was that bad you'd be taking out the valves.
#16 |
I hope they do!
I think I figured out my problem :/ Never again will I work on my engine for more than 12hrs at a time. Being rediculously tired is no way to work on a car. Lol so I put my valve spring retainers in upside down. I didnt even know they would fit like that, but bc they did they stuck up past the valve stem and created a clearance issue keeping all my valves apartially opened. Ill be the first to say.. Im an idiot!
#19 |
If it's an S13 motor then it does matter, the cams are 240/248. If S14 probably not, the cams are 232/232.
