Old 02-20-2012, 11:08 PM   #1
keMz
keMz is an unknown quantity at this point
Melting Fuses in my s13!!
basically my alternator fuse melted. i ran the alternator independant cause the oem fuse holder was all busted. my dad suspected it was the flex fans cause i had 40-50amps draw when you test the alternator wire that runs to the battery.
ive changed the fans and fuse holder... i got the fans running with 1 relay also...
now ive changed the alternator to a nissan quest 125a one...
the draw is still 40-50amps under max load with a/c, hids, dual fans...
has anyone had a similiar issue...
my car is a 91 nissan 240sx coupe se (originally automatic)
now she has sr20det, quest alt, a/c, redtop battery.
any kind of suggestions would help cause im stuck... my 89 fb which was my old car had the same swap but minus all these issues and quest alternator...
thank you
keMz is offline   Reply With Quote
