Old 02-23-2012, 12:54 PM   #1
ka24e
ka24e is an unknown quantity at this point
sr20 wonders
well i was just curious on wat things i shud look for when buying an sr off a local person? pretty much he got motor droped it in then never wired it up or started it cause he got into drag racing. the motor he has came from jdm engines. advice on shud i look for? he also had motor for a year covered up outside in car.
ka24e is offline   Reply With Quote
Old 02-23-2012, 01:03 PM   #2
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
there are a million threads on this exact question go to the top of the page to the search bar and get to work or if you simply browse and skim the reviews threads I am sure you will find the info you seek
some key things would be compression numbers, inspect everything thoroughly do a leak down on it, pull the valve cover off inspect the rockers and the cams look for any scoring ext.
Old 02-23-2012, 01:27 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Do you really have to make multiple threads asking the same question?
CLICK HERE!!!
Old 02-23-2012, 01:32 PM   #4
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
^ THIS!!
if you have to keep asking. don't buy it, buy a running one and swap it into your car. or buy one from a shop.
Old 02-23-2012, 01:41 PM   #5
Ninjamasta04
Ninjamasta04 is an unknown quantity at this point
There are reasons why he didn't start it up, like a poorly done or messed up wiring, or wrong timing.
Anyway the lesson here is never ever! buy some unfinished project, you might shell out more than what you are willing to pay for later on.
Ninjamasta04 is offline   Reply With Quote
