Old 02-25-2012, 11:30 AM   #1
Buntaseightsix
Buntaseightsix is an unknown quantity at this point
s13 please help me.
I have this problem with my 240 that it wants to stall each time i give it gas, have no idea what it could be. Ecu keeps throwing code 12 even though i have changed 2 working ones and 1 one brand new one. Also tried a different ecu light was off, but still same problem. Anyone who can help, please do.
Things I've done
clean iacv
cleaned throttle body
checked continuity on all three cables on the pigtail of maf and the red/black cable that leads to the relay, and made a new ground that lead to the chassis.
checked all vacuum lines, no leaks
timing on point at 18
fuel pressure is at 38 forgot what fsm says it is
new fuel filter
maf read .19 with ignition on, and 1.4 at idle
have been breaking my head for around a month now. video included. please help.
240sx stalling problem - YouTube
Buntaseightsix is offline   Reply With Quote
Old 02-25-2012, 11:49 AM   #2
Schwiegz
Schwiegz is an unknown quantity at this point
have you considered going back to a stock maf and seeing what happens?
Schwiegz is offline   Reply With Quote
Old 02-25-2012, 12:06 PM   #3
Buntaseightsix
i have and it holds an idle for about 2-3 seconds and it just stalls on its own
Old 02-25-2012, 01:15 PM   #4
trevor34
trevor34 is not welcome here anymoretrevor34 is not welcome here anymoretrevor34 is not welcome here anymoretrevor34 is not welcome here anymoretrevor34 is not welcome here anymoretrevor34 is not welcome here anymoretrevor34 is not welcome here anymoretrevor34 is not welcome here anymoretrevor34 is not welcome here anymoretrevor34 is not welcome here anymore
Just a stock maf? Even with continuity doesn't mean everything is ok. Could be a wire hanging on with one strand of wire. Try looking for splits or just make a jumper wire and see if it solves your issue.
trevor34 is offline   Reply With Quote
Old 02-25-2012, 01:28 PM   #5
Buntaseightsix
yeah its the stock g60 maf....im going to try that and see if that fixes the issue...will report back later today
Old 02-25-2012, 03:06 PM   #6
Buntaseightsix
havent tried the jumper cable yet since i need a ride to go buy some wires......anyone else have any ideas as to what it might be?
Old 02-25-2012, 06:55 PM   #7
trevor34
It has to be the maf because your car should die when you disconnect the maf while its running, well it does on my s14 anyways. I'd try the jumper its quick and easy to do you don't need to even cut the wires just pull the wire cover back and jump it straight to the ecu.
Old 02-28-2012, 05:48 PM   #8
Buntaseightsix
So I finally got around to doing the jumper wires to no evail. Anyone else have any suggestions, I found similar threads but they never post what it was that caused the issue. Please, anyone have any idea?
Old 02-28-2012, 05:59 PM   #9
ma.jomaa
ma.jomaa's Avatar
ma.jomaa is an unknown quantity at this point
I had the same problem with mine and it turned out to be fouled spark plugs, Not sure if its going to be the same with you but it doesn't hurt to check them. GL
ma.jomaa is offline   Reply With Quote
Old 02-28-2012, 06:15 PM   #10
Buntaseightsix
Just checked the plugs and they look sooty, I'm going to replace them and see what happens. Did you cel turn on as well?
Old 02-28-2012, 09:23 PM   #11
Buntaseightsix
Just changed the spark plugs and still nothin, anyone know if the car would run if the fuel pump had a bad ground?
Old 03-01-2012, 04:37 PM   #12
Buntaseightsix
Bump....anyone who could help?
Old 03-01-2012, 04:49 PM   #13
Vitzio240sx
Vitzio240sx's Avatar
Vitzio240sx is an unknown quantity at this point
check throttle position sensor, mines had the same problem... and new tps fixed it
"Men with guts attack those corners!"-Keiichi Tsuchiya
Vitzio240sx is offline   Reply With Quote
Old 03-03-2012, 01:56 PM   #14
Buntaseightsix
I had good reading on the old tps but changed it with a new one and still the same thing.....really frustrated at this point, anyone else?
Old 03-03-2012, 02:10 PM   #15
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
Have you cleaned your actual air filter? Checked you CTS? how's your battery/alternator? Any loose/dirty grounds? Fuel injectors leaking? Can you smell raw fuel in the cylinder after pulling spark plugs?
Mishkin_707 is offline   Reply With Quote
Old 03-03-2012, 02:24 PM   #16
Buntaseightsix
I clean the filter on a consistent basis, replaced the coolant temp sensor a not that long ago when my car would start up right away, have checked and cleaned all grounds, changed all the injectors to some newer one I has Latin around, and for the raw fuel I do notice a a real strong rich smell out of exhaust, the timing is on point and have new spark plugs
Old 03-04-2012, 10:43 AM   #17
Kingtal0n
Kingtal0n's Avatar
How about wrong maf sensor for the ECU?
Has it ever run correctly with that combo?
If the engine has good compression, correct ignition timing, and correct fuel quantity per cylinder event, then it will run right.
You hit the gas, what happens with the maf? The maf voltage spikes, the ECU responds by increasing fueling based on a non-linear map that is charted based on MAF voltage. If the maf sends the wrong voltage (incorrect maf, bad maf, airflow breach, bad wiring) then fueling will be wrong also.
code 12, maf, stall, wiring
