Old 02-25-2012, 01:02 PM   #1
ultimateirving
ultimateirving's Avatar
exedy Clutch oem vs stage 2, torque ratings, please help!
So i been shopping/searching around for a clutch and the concensus has been that exedy is the best for the money. What i noticed is that i was not able to find solid information reguarding torque ratings, so website stated good up to 290/ft lb of torque, while others said up to "400whp" i know clutches should be rated by torque so can anyone confirm that 290 is the limit of stage 2?
Second question is that I found that an exedy oem replacement was rated at 280/ft lbs, if thats true it is much cheaper of a clutch and can handle about the same power.. with that logic, would this ebay kit be acceptable since it includes a lightened flywheel?
EXEDY Clutch & FIDANZA Flywheel SILVIA S13 S14 SR20DET | eBay
Thanks ahead of the time for help
Z32 with lq4 swap
Old 02-26-2012, 10:13 AM   #2
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
What's your setup and what do you do, or plan to do, with the car?
A stock KA will burn through a stock clutch in a few clutch kicks. I've done it.
After I toasted the stock clutch I went to an Exedy stage 2 and Fidanza FW. Even though it took some serious time to get used to, I loved the setup. The clutch was practically an on/off switch and made clutch kicks a flick of the ankle. It's an incredible clutch on a stock KA. Once I did my SR swap I looked at the clutch after about 8 months of abuse and it looked practically brand new. I have a Spec stage 3 on my SR now, it just isn't the same, because I have to press the pedal farther to disengage I pretty much have to slip my foot off the side of the clutch pedal to get the same effect as the Exedy stage 2.
Hope this helps a little bit.
zombiewolf513 is offline   Reply With Quote
Old 02-26-2012, 10:25 AM   #3
jr_ss
Exedy underrates their clutches to protect themselves as the manufacturer. There have been multiple people that have taken their Exedy clutches over "rated" trq and lasted a long time. What torque level are you looking to be at? What motor? S13 SRs tend to make less trq than the S14/15 variations due to their lack of VTC.
Old 02-26-2012, 10:29 PM   #4
ultimateirving
Ended up buying a spec stage 3. Got a great deal from a local shop $300 bucks. Thanks for the input
Z32 with lq4 swap
Old 02-26-2012, 10:31 PM   #5
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
Originally Posted by jr_ss View Post
Exedy underrates their clutches to protect themselves as the manufacturer. There have been multiple people that have taken their Exedy clutches over "rated" trq and lasted a long time..
It's called incorporating a factor of safety.
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
