Old 02-28-2012, 07:09 PM   #1
danman
danman is an unknown quantity at this point
s14 steering problem
My steering wheel shakes once in awhile when im going at least 50 to 60 mph
idk whats going on it annoys me when i wanna go fast haha. any suggestion whats wrong? I do have blown coilovers and riding on 17"s
danman is offline   Reply With Quote
Old 02-28-2012, 07:47 PM   #2
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
That could be your problem. How's the alignment? Are your wheels correctly balanced?
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 02-28-2012, 08:11 PM   #3
cmg
cmg is an unknown quantity at this point
Check your rack bushings. Have a friend turn the wheel and see if the rack moves. Normally when your at the point your at now you can actually see where the rack has been moving back and forth.
cmg is offline   Reply With Quote
Old 02-28-2012, 08:33 PM   #4
Dorifto Machine
Dorifto Machine's Avatar
Dorifto Machine is a well-known jackass
This
Check to make sure all lugs are tight, Balance Wheels, Alignment, check TIRES....
Check steering rack and make sure it is bolted tight and check bushings.
Check Tie Rods , Wheel bearings..... Those are top culprits to weird steering problems.
Dorifto Machine is offline   Reply With Quote
Old 02-28-2012, 08:44 PM   #5
cmg
Originally Posted by Dorifto Machine View Post
This
Thats nearly all the suspension in the front haha. Normally know if its tire balance because its not a constant vibration. It will come and go within a noticeable rpm range.
Old 02-28-2012, 09:28 PM   #6
purplove
purplove's Avatar
purplove is an unknown quantity at this point
+1 for rack bushings/tie rods/alignment.
purplove is offline   Reply With Quote
Old 02-29-2012, 10:51 AM   #7
mr.man.performance
mr.man.performance's Avatar
mr.man.performance is an unknown quantity at this point
Check outer tie rods first. That's the most probable cause.
mr.man.performance is offline   Reply With Quote
