Old 03-02-2012, 03:24 PM   #1
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
s13 Constantly Updated - Part Out, S14 5 Lug, Endless, Project Mu, Brembo, Tons of Parts!
Updated March 14 2012 3:15am
Located:Oceanside and Orange County
I now have 2 more part out cars, white pignose hatch no motor trans, no holes in hatch, primer green hatch pignose
WTB One Piece Driveshaft s13 non ABS
WTB Hicas Rack
300zx Brand New Rear Brembo Rotors $95
Freshly Machined 300zx Rear Brembo Rotors $40
Special Ordered these pads, and went with a full race pad for the track instead.
Endless SS-Y 300zx/STI Rear Brake Pads Brand New(Unopened) $115obo
Project Mu B-Force 300zx Front(26mm or 30mm) Used, mostly freeway 3000-5000 miles? $85
Aluminum one piece driveshaftshop drive shaft almost brand new s13 w/ abs $350obo
S14 Peak Performance Brand New Front 5 Lug Hubs Comes w/ Studs and NTN Japanese Bearings $200
S14 Manual Seat Belts Front and Rear Set $75
s13 Manual Black Door Panels $80
s13 Power Black Door Panels $80
s13 Clean Grey Glove Box with Bracket $35
S13 5 Speed Driveshaft $80
S13 Welded Diff $80
S14 Brembo 5 Lug Front Rotors $80
S13 Radio Din Pocket w/ Radio Brackets $25
S13 Clean Grey Glove Box with Bracket (Handle is fine, picture is distorted) $35
S13 Ash Tray $15
S13 Hatch Moonroof Latch Not Broken $20
S13 Gas Latch Trim (slightly faded) $5
S13 JDM Cluster(I read that it will work with DOHC harness? I wonder if SOHC and DOHC harness r the same) $90
S13 DOHC Cluster(Harness extra)$75
S13 Passenger Window Switch $25
Power Window Amp $25
s13 Passenger Window Switchs Driver(No buttons) and Passenger $50
S13 Dome Light $10
Coupe Third Brake Light For Non Spoiler Trunk Lid $30
1991 Coupe Body Harness From Rear to Dash Manual Windows, No sunroof $100obo
KA Fan Shroud $30
S13 Left Kick Panel $10
S13 Steering Wheel Undertray Trim Piece $15
S13 Door Jam Interior Floor Trim Pieces $15
S13 Headliner Trim Piece $10
S13 Ash Try w/ Good Spring $15
S13 Steering Wheel Cover Trim pieces $15
S13 Bottom Half Steering Wheel Cover Trim $5
Clean S13 Radio Brackets w/ Din and 4 Radio Screws $25
HKS EVC EZ Boost Controller(Missing harness, but might find it) $120
S13 Coupe Black A Pillar Trims $20
S13 Coupe Black C Panel Trim(Arm Rest Pieces) $20
S13 Hatch Black A Pillar Trims $20
S13 Hatch Black B Pillar Trims $25
S13 Hatch Black C Panel Trims(Arm Rest Pieces) $20
Maroon manual passenger door, perfect, with harness and plug, manual side view mirror optional, comes with speaker box $65
Black manual passenger door, clean, with harness and plug $65
S13 Hood Hinge right side $5
S13 Trunk Hinges w/ Spring Rods $15
S13 DOHC Cams 248/240 (Used for upgrading DOHC cams for better power) $50each pair
S13 Black Gas Cap Cover $20
S13 Grey Headliner(From Coupe, Not sure if that is relevant) $30
S13 Guage Cluster Bezel $15
S13 Guage Cluster Clear Plastic Cover $7
Some KA brackets $5
Modified Sr20det Throttle Cable Bracket(For greddy style intake manifold) $10
Side View Mirror Lenses $12
Fuel Pump Wiring Cover Piece $5
New s13 NSK OE Quality Wheel Bearing $50obo ($60+Tax new)
Headlight Black Trim Covers $20 a pair
Auto Transmission Crossmember $15
DOHC Cluster Harness $20
Clean Pink Fuse Box Cover Lids $10 each
Coupe Rear Bumper Support $30
Coupe Rear Bumper Foam $10
Make some offers
Exedy Stage 2 Clutch Kit Used(Disc probably needs to be repadded, but I am not sure)$50obo
Sr20det Coolant Temperature Sub Harness w/ Broken Clip $10
Rear Parking Lights $15
Sr20det Coolant Temperature Sub Harness SOLD
Nissan Oem Jack w/ lug wrench(otherwise ill keep it) $40obo
Rear Trunk Plugs $3 for big one $2 for little ones
Stock SR20DET Intake Manifold Comes with whatever in picture, No IACV, No Throttle Body $40
Stock s13 Coupe Automatic Brown Seat Belt System w/ Ecu Rails, Belts minus driver belt, Ecu $30
Regular Straight 2" Stock Hotpipe SR $10
Stock SR20DET Thermostat $5
Front s13 240sx Stock 24mm Sway Bar $10
More random things, good exhaust hanger and some new and used gaskets, one gasket has a tear. Most of these things I list just in case someone needs it.
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 03-03-2012, 06:45 AM   #2
mike99101
mike99101's Avatar
mike99101 is an unknown quantity at this point
Can I have a price shipped to 06249 on the interior door jam trim pieces
Thanks
I love sliders !!
mike99101 is offline   Reply With Quote
Old 03-03-2012, 06:51 AM   #3
240sxgabriel
240sxgabriel is an unknown quantity at this point
Got more pictures of the clutch? miles? shipping to canada? thanks.
240sxgabriel is offline   Reply With Quote
Old 03-04-2012, 01:16 AM   #4
Nismo_Chris
Nismo_Chris is an unknown quantity at this point
Couple things..... The 3" exaust gaskets and if youl sell the pasenger side mirror off the door. mine is missing the glass but im not sure if one of the ones you have will completely cover whats missing on mine. how much shipped to florida.
Nismo_Chris is offline   Reply With Quote
Old 03-04-2012, 01:26 AM   #5
Vatche
Vatche's Avatar
Thanks
25 shipped
Shipping flat rate box to canada is $40 +tax and paypal so 90 shipped.
I am not sure how many miles are on it i cant remember. it was pulled out because i installed a lightened flywheel and clutch combo that were mated together when i had my tranny out.
Here are pics:
if the side view mirror fits in a medium flat rate is would be 35 shipped
large flat rate 40 shipped
Old 03-04-2012, 01:53 AM   #6
jeremyuhh
Trader Rating: (51)
jeremyuhh is an unknown quantity at this point
Feedback Score: 51 reviews
if i were to buy the whole maroon door, including the mirror, can i pick it up in the OC? and are there any dents on it ?
jeremyuhh is offline   Reply With Quote
Old 03-04-2012, 02:13 AM   #7
Vatche
Vatche's Avatar
Yes door can be arranged for pick up in oc with mirror. There are no dents on it either.
Old 03-04-2012, 10:19 AM   #8
jeremyuhh
Trader Rating: (51)
Is the color code ah3?
Old 03-04-2012, 11:05 AM   #9
Vatche
Vatche's Avatar
Im not sure what code it is. But this is maroon off a 91 coupe.
Old 03-04-2012, 11:22 AM   #10
seagrasser
seagrasser is an unknown quantity at this point
Interested in the rear rotors. Looks like they are drilled 4 and 5 lug. If so, pm me price shipped to 98020
seagrasser is offline   Reply With Quote
Old 03-04-2012, 01:32 PM   #11
Vatche
Vatche's Avatar
Yeah it looks like they are. Ill do 60 shipped.
Old 03-04-2012, 02:05 PM   #12
seagrasser
Assume this is the fresh turned pair. How much meat is left or how many times turned?
Is the new pair also 4 and 5 lug drilled?
Old 03-04-2012, 02:10 PM   #13
Vatche
Vatche's Avatar
I cant remember exactly the numbers, But I know I had measured and it was 1mm thicker or more than the minimum, the measurement was in between brand new and minimum. 1 time turned. There is nothing wrong with them, they have meat left, and they were turned by professionals.
The new rotors are 5 lug new in box. They are still cheaper than buying retail so you can afford to drill them if needed.
I can do 105 shipped on the new
Old 03-04-2012, 02:45 PM   #14
TheSquidd
TheSquidd's Avatar
PM Price shipped for the ashtray to 91764
Thanks.
TheSquidd is offline   Reply With Quote
Old 03-04-2012, 09:34 PM   #15
foggygoogleso.O
foggygoogleso.O's Avatar
Trader Rating: (18)
foggygoogleso.O is an unknown quantity at this point
Feedback Score: 18 reviews
ill take that maroon door off your hand and rear parking lights. 75 bucks? i can pick them up next sunday.
lmk thanks.
foggygoogleso.O is offline   Reply With Quote
Old 03-04-2012, 09:58 PM   #16
Nissan206
Nissan206's Avatar
Nissan206 is an unknown quantity at this point
How much for the Coupe Third Brake Light For Non Spoiler Trunk Lid, S13 Headliner Trim Piece, and S13 Grey Headliner shipped to 98058? PM me the price.
Nissan206 is offline   Reply With Quote
Old 03-04-2012, 11:07 PM   #17
Vatche
Vatche's Avatar
Thanks.
pm'ed
lmk thanks.
currently pending, ill let you know, are you interested in a black door?
I can do 40 shipped for the brake light, but I cant ship you the headliner man. It would just be way to expensive.
Old 03-04-2012, 11:28 PM   #18
Nissan206
Nissan206's Avatar
Originally Posted by Vatche View Post
pm'ed
I will get back to you. Also one of the black passenger side door handles not the plastic piece that goes into the door panel.
Old 03-04-2012, 11:34 PM   #19
Vatche
Vatche's Avatar
no sorry i cant do 40 shipped for both. if i have to ship the headliner trim and the third brake light it would change the box completely and I would need to get you a whole new estimate. I would assume shipping those 2 items together is going to make shipping annoying and expensive. if i shipped them seperately it might be cheaper , not sure until i get an estimate.
Old 03-05-2012, 12:58 AM   #20
Nissan206
Nissan206's Avatar
Alright how much for just the 3rd brake light and 1 black passenger side door handle shipped?
Old 03-06-2012, 01:59 PM   #21
Vatche
Vatche's Avatar
50 shipped cuz i didnt really want to take parts off the door.
Old 03-08-2012, 10:42 AM   #22
Vatche
Vatche's Avatar
Alright so i have 2 almost complete hatchbacks now one is white and one is primer green. im gonna have to start new threads coming soon. but if someone reads this before then hit me up for parts i have way tooooo many right now. need to get them moving and make a little money to fix my strut tower.
white one has no holes in hatch.
primer green has perfect fenders pignose
white fenders are not bad either but have some ripples or dents dings here and there, not bad ones. I will get this shit going asap
Old 03-11-2012, 01:59 AM   #23
Faztkarvroom89
Faztkarvroom89's Avatar
Faztkarvroom89 is an unknown quantity at this point
How much for the pair of pignose fenders?
Faztkarvroom89 is offline   Reply With Quote
Old 03-12-2012, 01:28 PM   #24
Vatche
Vatche's Avatar
ok i typed a long response a few times on my phone and it deleted both times, so ill respond through my computer this time.
I added and am adding many many new parts, I tripled my collection at this point and have 2-3 of everything.
I have 3 sets of fenders right now, I believe 2 sets are pignose and of the third set driver is pignose and passenger is chuki.
The price is depending on the condition of each set, the primer green pignose fenders are perfect condition
The white pignose fenders are not perfect
And the pignose driver and chuki passenger are both in excellent condition with minor issues.
I have been hit up for pictures multiple times but i was away for work over the weekend and am at work now until later today. I apologize to everyone who is waiting on me, for some reason there is not enough time in the day.I am working on getting all questions answered and all pics taken.
I can answer any and all questions just give me some time to catch up . thanks :P
Old 03-12-2012, 02:47 PM   #25
[email protected]
Paul@mastermindna.com's Avatar
Paul@mastermindna.com is an unknown quantity at this point
$40 for the fan shroud shipped to 20817? $ ready to go. PM if interested
Paul@mastermindna.com is offline   Reply With Quote
5 lug hubs, brembo, endless, part out coupe, project mu
