Old 01-20-2004, 02:29 PM   #1
240silvia
240silvia's Avatar
240silvia is an unknown quantity at this point
Send a message via AIM to 240silvia
SR Valves are ticking, help!
Hey guys, well my valves started ticking. Now, I know that if the pivot is hydraulic, they can't be adjusted. What is the SR? Also, can they be adjusted? If they can't be adjusted, what should be my next step to make the ticking stop?
240silvia is offline   Reply With Quote
Old 11-24-2008, 06:17 PM   #2
besTint
Trader Rating: (81)
besTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the rough
Feedback Score: 81 reviews
Send a message via AIM to besTint
mine sounded like it had sticky lifters so i bought a bottle of CD2 (yellow bottle) saids its quites and cleans sticky lifters. i had to use 2 bottles and it went away.
http://squarespokes.com/
besTint is offline   Reply With Quote
Old 11-24-2008, 06:44 PM   #3
Sileighty_85
Sileighty_85's Avatar
Lifter Tap on an SR could also be a sign of low oil puressure.
Oil pump might be on its way out, get an oil puressure gauge and check the pump.
If oil pruessure is fine you might have air in the HLA's.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-24-2008, 06:54 PM   #4
devnull
devnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymore
SR20s have hydraulic lifters...if you suspect lifters, the proper way to prime them is to remove them and pump them while they're submerged in engine oil. You must ensure that they do not get turned on their side or upside-down after you prime them.
A tick that starts suddenly out of nowhere indicates a lifter problem.
devnull is offline   Reply With Quote
Old 11-24-2008, 08:14 PM   #5
corey240
corey240's Avatar
corey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymore
Send a message via AIM to corey240 Send a message via MSN to corey240
Get the fsm for the sr. Look it up on here. I cant get the links to work on the websites to good luck man. Just bleed your lifters, make shore you do them right. If the problem is still there, get an oil pressure gauge. But I would highly reccomend an oil pressure gauge on any modified car, ESPECIALY an sr20. And dont buy a cheap ass one either. Thats where I made my mistake, 15 psi? No. New gauge read whatever it said I forget but it was right. I made a thread about it lol.
Email: [email protected]
corey240 is offline   Reply With Quote
