Old 03-14-2012, 09:57 PM   #1
RandallSharp
RandallSharp's Avatar
RandallSharp is an unknown quantity at this point
Brake Tune-up
Hey guys, my front brakes are shot to crap on my s13 and so is my passenger ball joint. I'm on a restrictive budget, but I think I've finally put together the parts I'm going to get. Before I buy them, can I get some feedback to determine if this is the right route and worth the upgrade?
RAYBESTOS 507-1311 Control Arm/Ball Joint Assy | eBay
Centric Parts 105.07000 Front Original Equipment Ceramic Pads | eBay
Centric Parts 121.42041 Front Disc Brake Rotor | eBay
My concern with the rotors, is that it does not specify if it's for ABS or not. How do I tell? I do not have ABS.
As for the pads, I don't believe it comes with shims and I cannot find the kit it requires. Does it actually come with shims or should I avoid these for that reason?
If you were going to do this, would you recommend different parts? I would like to end up paying no more than $150 for everything.
Thanks for reading.
1991 240sx Hatch Daily'd!
RandallSharp is offline   Reply With Quote
Old 03-14-2012, 10:05 PM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Autozone for pads / rotors.
Duralast/Brake Rotor - Front (3215) | 1991 Nissan/Datsun 240SX 4 Cylinders M 2.4L SFI DOHC | AutoZone.com
Duralast/Brake Pads - Front (MKD422) | 1991 Nissan/Datsun 240SX 4 Cylinders M 2.4L SFI DOHC | AutoZone.com
pdm-racing.com for the control arms.
PDM Racing - Specials
Old 03-14-2012, 10:34 PM   #3
zo0d
zo0d's Avatar
zo0d is on a distinguished road
Go to advanceautoparts.com
I just added all your items and entered the coupon code:MA30. It came out to 125.83. You also get a $50 coupon towards your next purchase of $100 or more.
Order the parts online and then pick them up at the store.
zo0d is offline   Reply With Quote
Old 03-14-2012, 10:53 PM   #4
RandallSharp
I can't afford $200 for the AutoZone and the nice control arms. I was looking at the specific setup because I know Centric makes StopTech and PowerSlot, so they must be of good quality. The Rotors are unbeatably priced and I was aiming for ceramic pads. As for the LCA, I know Raybestos is good stuff. So my picks were really that bad you guys would recommend FailZone items over it?
Old 03-14-2012, 11:36 PM   #5
KiLLeR2001
Trader Rating: (46)
It's not that, its just you have to be careful from what you buy on eBay. I try to limit purchases on eBay as much as possible.
The rotors you chose are actually the ABS rotors. If you note, ABS rotors have a thickness of 22mm and non-ABS have a thickness of 19.89mm or ~20mm.
Old 03-14-2012, 11:44 PM   #6
RandallSharp
Well what I actually did was do all of my researching on Google and found out the part numbers on RockAuto.com. I've been desperately researching for 3 days to no avail, lol. I figure if they title it a name brand, have sold some, and have a good rating, it's probably legit. I've used eBay a good amount and I've always been satisfied.
As for the ABS thickness, that is something I was not aware of. Truly appreciate the information, I'll look for non-ABS rotors
EDIT: I found these on eBay and I've been researching them. Everyone seems happy with them. Any opinions?
http://www.ebay.com/itm/FRONT-REAR-K...ht_6325wt_1396
