Old 03-21-2012, 12:47 PM   #1
Stunt'nSlide
Trader Rating: (-1)
Stunt'nSlide is an unknown quantity at this point
Feedback Score: -1 reviews
nx1600 in sohc 240sx?
I've searched every where and it only shows how to di it using a dohc cluster harness. i've wired it up and everything works except for the tach. The tach wire for the nx1600 is blue/black and the wire for the sohc cluster tach is yellow/red. there connected and it still doesn't work. it worked on my sohc cluster
Stunt'nSlide is offline   Reply With Quote
Old 03-22-2012, 04:23 PM   #2
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
What...in...the...hell....?
cdlong is offline   Reply With Quote
Old 03-22-2012, 04:33 PM   #3
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
If the nx1600(I know nothing of them) is a dual cam, that's why. Same reason you need to use a tach from a dual cam when you swap to an sr or ka24de.
di-devol is offline   Reply With Quote
Old 03-28-2012, 07:13 PM   #4
Stunt'nSlide
Trader Rating: (-1)
Is there any way around this because there are people that used a single cam cluster in a dohc with working tach because they wires it straight to the ignition coil
Old 10-30-2012, 07:55 PM   #5
MintGreenSpecial
MintGreenSpecial is an unknown quantity at this point
I am bumping this up, as I am having the same issue. I even went as far as buying a tach convertor and still wouldnt work. anyone?
MintGreenSpecial is offline   Reply With Quote
