03-23-2012, 10:08 AM | #1 |
New Release: Precision Turbo Releases All New PT6466 CEA Turbocharger, Shipping NOW!
New Release: Precision Turbo and Engine has released the highly-anticipated 6466 CEA ball-bearing turbocharger which features the latest and most powerful technology available. A revolutionary unit which uses the most cutting-edge technology available and is rated to support 900 HP, the 6466 CEA (part number PTB505-6466 B) showcases an all-new 64mm Competition Engineered Aerodynamics (CEA) CNC-machined, 2618-forged aluminum compressor wheel and high-flow 66mm CEA turbine wheel. Precision’s 6466 CEA turbocharger will be offered with an air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA) and utilizes PTE’s “Ported S” cover compressor. As noted in the table below, a multitude of turbine housing options are available to best fit a wide variety of applications and provide the ability to customize and fine-tune the turbo’s performance. Ball Bearing Only PTE's PT6466 CEA Turbocharger features the following: • Exclusive CEA (Competition Engineered Aerodynamics) compressor wheel machined from a 2618-aluminum forging • Higher efficiency and faster transient response for maximum power and performance • 64mm inducer compressor wheel • Compressor cover options: - "Ported S" compressor cover 4.0" inlet/2.5" outlet • Exclusive CEA (Competition Engineered Aerodynamics) 66mm, 76 trim turbine wheel • Turbine housing options: - T3 .63 or .82 A/R with 4 bolt (2.5 inch discharge - T3 .63 A/R with 5 bolt discharge (with or without wastegate hole) - T3 .63 or .82 A/R with 3" V-Band discharge - V-Band inlet .82 A/R with V-Band discharge - T4 .58, .68, .81 or .96 A/R with 3 5/8" V-Band discharge - T4 Divided .84, 1.0, 1.15 or 1.32 A/R with 3 5/8" V-Band discharge - Buick .63 or .85 A/R - GMC Syclone/Typhoon .85 A/R • Available with an air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA) PM or post up for pricing.
940-683-8282 x20 Robert Del Angel CLICK HERE FOR OUR FACEBOOK PAGE!!! FOLLOW US ON TWITTER!!! Master Distributor for : RPS, Tein, Seibon, Haltech, HKS, Greddy, Cusco, Blitz, Koyo, AEM, Map ECU, Eibach, Tokiko, Power Enterprise, Work, Volk, Fidanza, Defi, ....and so many more!!! |
03-23-2012, 10:23 AM | #3 |
The press release was just sent out this morning so unfortunately testing has not been done at this point in time. This turbo is a middle ground for the 62's and the 67's. I would imagine spool would be compromised very much at all. Your peak power should yield a nice noticeable gain when compared to the 62's. Regards, Robert
03-23-2012, 02:39 PM | #4 |
Testing has been released for Supra's.
New precision 6466 This is a graph with the turbo's "all in" on a very maximized setup: This is a graph of the turbo's at 36 psi on a slightly less extreme setup:
93' KA-T *Sold*, 00' Corvette *Sold*, 03' EVO *Sold*, 94' Supra *sold*, 02 Z06 Current |
03-26-2012, 12:25 PM | #5 |
Awesome thank you for the graph!!
Regards, Robert
