Old 03-26-2012, 08:08 PM   #1
thizzen4
Trader Rating: (22)
thizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymore
Feedback Score: 22 reviews
Question help 3 injectors are spraying other one isnt and injector is good
cars idoling like shiyt bouncin from 300-700 rpm and dieing and wi can drive it but when get on it ... 3000-5000 rpm it will cut out and back fir and lag and loose power
ANY IDEAS HOW TO START OR WHERE TO START LOOKING
thizzen4 is offline   Reply With Quote
Old 03-26-2012, 09:02 PM   #2
ultimateirving
ultimateirving's Avatar
swap injectors around first to see if its the harness thats bad or injector is clogged.
If none of the other injectors work on that clip, that means there is a short somewhere. try tracing the wires from that clip, back to the PCM. If you have a volt meter, try doing a continuity test to make sure there is no breaks in the wire.
Z32 with lq4 swap
Old 03-27-2012, 02:29 PM   #3
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
If you can, swap ecu's first before all the other work.
I had an ecu that was like that and only 2 of the cylinders worked.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 03-27-2012, 10:41 PM   #4
cotbu
cotbu's Avatar
The first thing you should do is make sure there is 12v going to the injectors. you don't have to wait for an ecu, and you don't have to swap around injectors, if you wiring isn't long enough. Anyway if there is 12v present then it's a ground issue. Short answer, wiring or ecu.
Old 03-27-2012, 11:00 PM   #5
thizzen4
Trader Rating: (22)
thanks peps should have it all good tomorrow if not all let everyone know
Old 03-28-2012, 01:20 PM   #6
thizzen4
Trader Rating: (22)
could it be maf when i unplug it it idols the samee
Old 03-28-2012, 02:28 PM   #7
cotbu
cotbu's Avatar
It could be anything, but the mafs is not going to make one injector not fire! Did you do my test or any testing? Power balance? Or are you saying you don't think it's an injector problem. A mafs issue should throw a code. You won't have to guess. Do some testing cause there ain't now way around it!
http://www.youtube.com/watch?v=9cQjsVfhGmI
Old 03-28-2012, 06:55 PM   #8
thizzen4
Trader Rating: (22)
ha and cotbu songs not to badd
all injectors seem to be spryain and ticking and all are getting power and so is the maf plugg and ecu isnt throwing any codes. well at least the ecu lights not comming on
could it be a bad ecu ?
just bought a new one this weeek cause other one from tiger jap was burnt..and smelt
Old 03-28-2012, 06:56 PM   #9
thizzen4
Trader Rating: (22)
And so my injectors should be getting 12 volts? Or its a ground issue if they are getting 12 volts
Old 03-28-2012, 08:01 PM   #10
thizzen4
Trader Rating: (22)
Actually cant get that song out my head and keep bumpin it and thinkin how to fix this damn coupe
Old 03-28-2012, 08:52 PM   #11
cotbu
cotbu's Avatar
Unless your engine is obdpo, it won't show codes unless it's a major malfunction.
You have to manually pull the codes that get stored, cas, mafs, etc.! Even though there is no check engine light.(all it take is a low voltage from most of the sensors) Every time your engine idles funky pull codes. WOW.
Your injectors should have a constant 12v. All of them all the time. The ecu controls the ground. Your post tend to confuse and bewilder me, if you say
you don't have an injector problem.
Take a few hours out of the day and do these test and come back with the answers. The few hours also include looking up what these test are, and how to perform them.
Code:
1.Check ecu for codes
2.Power Balance
   a.spark
   b.fuel
3.check timing /w light
3.read plugs
Old 03-28-2012, 08:55 PM   #12
thizzen4
Trader Rating: (22)
K i will tomorrow thanks !
Old 03-30-2012, 07:41 PM   #13
thizzen4
Trader Rating: (22)
made a new thread since injectors are good adn got power to everything adn got a new maf and ecu
