Old 04-01-2012, 03:56 PM   #1
CurleyMerkin14
CurleyMerkin14's Avatar
CurleyMerkin14 is an unknown quantity at this point
injector stuck on!!!>??? wtf mate what do i do?
so its a rb25 injector 3 is stuck on its not the injector it self i switched it with 2 others and it still just stays on that cylinder also it comes on as soon as the ignition goes on ... like im not trying to start it i just turn the power on and SPLASHHHH that injector goes nuts anyone know why this is ?bad ground some where ... ecu went homo?
CurleyMerkin14 is offline   Reply With Quote
Old 04-01-2012, 04:16 PM   #2
CurleyMerkin14
ok so i limited it down to the plug ..ifi put the plug for injector 3 in any other one it fires constantly how do i make it not do that???!!!
Old 04-01-2012, 06:31 PM   #3
Sileighty_85
Sileighty_85's Avatar
Re check the Wiring Harness
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-01-2012, 06:37 PM   #4
CurleyMerkin14
Yea just took the harness for the injectors all the way apart it looks yo be all good fallowed the wire to the ECU and it is also in good condition its just that one plug no matter with injector I plug it into it just blast fuel
Old 04-01-2012, 08:17 PM   #5
CurleyMerkin14
come on guys!!! i really need help with this im pretty stumped
Old 04-01-2012, 11:54 PM   #6
VinceDude
VinceDude's Avatar
VinceDude is an unknown quantity at this point
could be your actual ecu. I'm pretty sure if it's a fuse all the injectors would be going crazy so i don't think it's that. Could be your wiring too bad ground maybe(long shot)? If all else fails it's prolly your ecu but don't quote me on that.
VinceDude is offline   Reply With Quote
Old 04-02-2012, 01:45 AM   #7
cotbu
cotbu's Avatar
Eliminate the wiring for that cylinder(injector): Depin at the ecu for the trigger ground, run a wire from the ecu to the problem injector. Do a KOEO verification, If that injector still has an issue it's the ecu!
Key On Engine Off
If you do pass that test, I wouldn't see any harm in firing it up!
Old 04-02-2012, 06:14 PM   #8
CurleyMerkin14
sweet shit dude ! ran new wire to the ecu from the injector and POW! it works!thanks for all the help!
