Old 04-04-2012, 05:51 PM   #1
JZenki
JZenki's Avatar
JZenki is an unknown quantity at this point
Sound deadening in s-chassis
Need some opinions&tips from who has done this, some pics would help..
Coming from a previous m3 owner, I truly miss the quiet cabin and minimal engine vibration shaking the chassis.. I plan on installing it through out the full chassis, roof, pillars, trunk and just about anywhere you can think of, so I can achieve that good luxury modern feel as this will serve as my daily driver for the years to come..
JZenki is offline   Reply With Quote
Old 04-04-2012, 06:04 PM   #2
Jtuned_andy
Jtuned_andy's Avatar
Trader Rating: (28)
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
Feedback Score: 28 reviews
If you use dynamat or equivalent in the quantities you are talking you will add A LOT of weight to your car if you are interested in performance at all.
What I did was strategically place dynamat where I felt noise and vibrations would be able to come through my chassis with the least restriction ie. trans tunnel, firewall, trunk floor above differential.
When I had my dash out for my overhaul I completely dynamat'd that area from floor to windshield and will add more to the areas I suggested above to complete my project.
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 04-04-2012, 06:34 PM   #3
Sumslapper
Sumslapper's Avatar
Sumslapper is an unknown quantity at this point
^^ So how is it? Noticeably quieter? I always though about doing this to my car as well.
Sumslapper is offline   Reply With Quote
Old 04-04-2012, 06:38 PM   #4
Duker
Duker is an unknown quantity at this point
look into second skin audio's products, i just sprayed my Z32 interior in their spectrum coating and it made a petty big difference. I used 3 gallons at 9lbs per gallon after curing. Granted 3 gallons on a completely gutted/empty shell. If you sprayed it on the the trans tunnel and fender wells it will help.
Duker is offline   Reply With Quote
Old 04-04-2012, 06:50 PM   #5
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
Just a note, there is a definitive difference between Dynamat-like materials that are meant to reduce the resonance of metal panels, and sound deadening materials that 'absorb' sounds from the ambient interior.
Both materials are also heavy, so they have to be used sparingly. The Dynamat type stuff goes on big open metal panels, then sound deadener goes behind interior body panels and under carpeting.
If you want the M3 type of quiet interior, you want more sound deadening materials than you want Dynamat.
Seraphim38 is offline   Reply With Quote
Old 04-04-2012, 06:54 PM   #6
EmpyreS13
EmpyreS13's Avatar
EmpyreS13 is an unknown quantity at this point
Lizard Skin works wonders LizardSkin 50115 - LizardSkin Sound Control Insulation - Overview - SummitRacing.com
EmpyreS13 is offline   Reply With Quote
Old 04-04-2012, 07:27 PM   #7
JZenki
JZenki's Avatar
I read in an ancient thread, if you remove the oem sound deadening and replace with dynamat I should break even.. I also read theres "brown bread" which works as good as dynamat and is cheaper, can anyone vouch for that?.. anybody write ups out there? I wouldn't want to miss anything before I reinstall everything..
Old 04-04-2012, 08:56 PM   #8
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
No offense but if you want something quiet...the last thing you need is a 20 yr old chassis thats beat to hell. Anything and everything squeaks in these damn cars.
CLICK HERE!!!
Old 04-06-2012, 01:43 PM   #9
2iv0 sx
2iv0 sx's Avatar
2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute
I hate road noise anyone with good results?
2iv0 sx is offline   Reply With Quote
Old 04-06-2012, 01:57 PM   #10
dopplganger1
dopplganger1 is an unknown quantity at this point
I did everything in mine hatch area, roof, pillars, floor, doors and it made a noticeable difference for me, with an SR full kouki areo, no front crash bar, stance coils, all adjustable arms, no sunroof, full interior, small sub and almost full tank of gas my car was 2700-2800 lb. I cant remember the exact number and I left the stock sound deadening and I believe it was fatmat that I used with a little bit of dynamat
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
dopplganger1 is offline   Reply With Quote
Old 04-06-2012, 02:05 PM   #11
thedeadking
thedeadking's Avatar
Trader Rating: (18)
thedeadking is an unknown quantity at this point
Feedback Score: 18 reviews
I recommend fatmat. You can get it off Amazon in different quantities and it ships quickly too. It's also MUCH cheaper than Dynamat.
thedeadking is offline   Reply With Quote
Old 04-07-2012, 11:05 AM   #12
bllabong89
bllabong89 is an unknown quantity at this point
Just did it about a year ago in my s14. If you are doing this, you usually aren't concerned with 40 extra lbs. I worked at a car audio shop for about 4 years and dynamat and like products are great but the cost is a joke IMO.
I went to home depot and bought roofing flash. It is almost identical, has no odor, is as easy to work with and cost about 15 a roll. I did my interior with 3 rolls.
Again, this is my opinion and choice so hopefully it helps.
bllabong89 is offline   Reply With Quote
Old 04-07-2012, 11:33 AM   #13
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
bed liner.
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 04-07-2012, 01:04 PM   #14
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
Im interested in doing this as well, ill keep an eye on these thread for somr good advice
andisan is offline   Reply With Quote
Old 04-07-2012, 01:22 PM   #15
JZenki
JZenki's Avatar
Just may look into that, thanks for the info!!! did you cover the whole interior?
Old 04-08-2012, 06:15 PM   #16
LUCKYxS13
LUCKYxS13's Avatar
LUCKYxS13 is an unknown quantity at this point
Send a message via AIM to LUCKYxS13
I was gonna say bed-liner underneath the car and rustolleoum, however you spell that lol, paint on the inside. I plan on doing this as im not bothered with road noise that much. But im sure it will make a noticeable difference and not add any weight lol!
LUCKYxS13 is offline   Reply With Quote
Old 04-24-2012, 10:35 PM   #17
Krewlkid
Krewlkid's Avatar
Trader Rating: (26)
Krewlkid is an unknown quantity at this point
Feedback Score: 26 reviews
just ordered 50 square feet of fatmat. shipping weight is 18 pounds.
will let you know how it comes out.
btw all stock SR with, 10lb flywheel, aluminum drive shaft, stock exhaust.
going for quick and quiet
Krewlkid is offline   Reply With Quote
Old 04-25-2012, 12:49 AM   #18
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
i bought a few feet of 'brown bread' know known as b quiet ultimate.
everyone should check out their site it is very informative. B-Quiet sound deadening materials - Brown Bread - Better than Dynamat!! brownbread
anyways, i used it in strategic locations but did not notice a big difference.
also in regards to using sound deadener/dampener in our cars, people are always SOOO concerned about how heavy itll make it, but the added poundage is really negligible. were talking about dozens of pounds here, if that, NOT 100s. the old recipe is '10lbs lost/gain = 1 hp' so yeah to me a few hp are definitely negligible and will be unnoticed.
dawagarage is offline   Reply With Quote
Old 04-25-2012, 01:20 AM   #19
RevTonyG
RevTonyG is an unknown quantity at this point
I'm actually in process of removing the sound deadening on my s13 right now. I'm not sure if I'm helpful when it comes to an aftermarket alternative, but this stuff is really fun to remove. I've posted some pictures on my website, revs240.com (not trying to promote, just saying they're there if you want to look). My car's a slow work in progress. I posted a picture of this 3M Adhesive, Tar and Wax remover that works wonders on this crap. (first post on here, btw).
RevTonyG is offline   Reply With Quote
Old 04-25-2012, 01:39 AM   #20
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
i just used dynamat on my car, shit is heavy lol. nothing compared to stock deadening. plus you'd use more dynamat to cover the surface area, cause why would you have spots of dynamat scattered on the car lol made a difference for sure.
- Hong
Old 04-25-2012, 01:42 AM   #21
Edwin562
Edwin562's Avatar
I use dynamat on my speakers, other than that i use lizardskin.
Old 09-28-2012, 02:58 AM   #22
JZenki
JZenki's Avatar
Bringing this back from the dead, does lizard skin or second skin audio's spectrum smell? Don't want the lady to feel sick everytime she gets in the car.
Old 09-28-2012, 11:24 AM   #23
dawagarage
dawagarage's Avatar
have you read up on that site? some good info, talks about the different kinds of materials and their uses. i bought from there (brown bread is now "b quiet, btw) it was definitely cheaper than dynamat, but also a little bit thinner.
all the dudes that say the shit is 'so heavy'.... can you define 'so heavy'? 10,20,50, 100, 200 lbs? if its between 10 and 100 lbs, i wouldnt call that 'heavy.' if the old myth of 10lbs = 1 hp, well, you arent really losing a lot of power. plus, a lot of people carry random shit in their car that also contributes to adding weight. shit, you can take a shit and lose almost 5 lbs. anyways, i wish i could add more to the effectiveness aspect, all i can really say is maybe we shouldnt worry too much about adding weight.
formerly known as "hotboiblaze"
ratsun: dawa (73 datsun 620)
clublexus: properD (97 sc300)
