Old 01-28-2004, 01:56 PM   #1
nissandrift
nissandrift is an unknown quantity at this point
Send a message via AIM to nissandrift
KA Car Problems- MAFS?
My car ( 1993 240sx SE w/ stock KA24de) was having problems stuttering about 2 weeks ago, anyways the next day it pretty much dies. It dies every time I try and give it gas, but start and idles fine. I unplug the MAFS and it runs fine until 2500, just a little rich. I figure its the MAFS and its runn9ing in safe mode. Well anyway i check voltage on it and its getting 14.5 volts in and putting .37 volts out when plugged in. Anyways I buy a used MAFS and it got here today. When I put it all back in and plugged it up my car does the same thing. I figure its worth a shot to unplug the negative battery cable and maybe reset ECU, I know its needed with OBD2 but unsure with OBD1. Im wondering do you think I got a bad MAFS, or does the problem lie elsewhere? Does anyone have and S13 in the johnston, or wake county area that would let me borrow theres for a bit so I can try your MAFS? Im willing to pay a little.
nissandrift is offline   Reply With Quote
Old 01-28-2004, 02:44 PM   #2
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
Have you tried to actually reset the ECU yet?
Ghettokracker71 is offline   Reply With Quote
Old 01-28-2004, 08:44 PM   #3
nissandrift
I've taken my ground cable off the battery for about a half hour. Is there another way to do it with OBD1?
Old 01-30-2004, 10:37 AM   #4
nissandrift
I was told to check my PCV. I looked through the FAQ's and it sound like a pain in the ***. I'll have access to a lift on tue., would it be easier to get to from underneath? Does anyone else think my PCV valve could be the prob.? I tried to check codes but couldnt get the light to come on regardless if the car was running, key on, or completely off. After that I just unplugged it overnight to reset.
Old 01-30-2004, 12:06 PM   #5
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
pcv from under the car? who told you that? it should be on your valve cover or somewhere around there
Hi
Var is offline   Reply With Quote
