Old 01-31-2004, 11:11 AM   #1
Rennen
Rennen's Avatar
Rennen will become famous soon enoughRennen will become famous soon enoughRennen will become famous soon enough
Suspension Prices for S13
Well Missouri roads have finally killed my shocks, and it is time to find a replacement. I am still undecided about coilovers vs a good spring shock combo, so I have decided to put together a table that shows what I can get for the price.
I would like your help with this, if you see anything in the attached table that is wrong, or if you know of another vendor that sells any of the products, please post and let me know. Also, you will see that I left out Apex'i, HKS, and Zeal coilovers. This is because I didn't find a lot of information on them, so if you know any of the specs on any comparable coilovers please post that as well.
I am not really seeking opinions about which set up would be good for me, I will make that final decision myself, but if you happen to have any 1st hand knowledge on what makes a good daily driver/autoX setup, let me know.
Oh, and in case any companies get mad, these are the prices as seen on the vendor's webpages on Friday, Jan 30th 2004 and could be misplaced a cell or two.
'89 Nissan 240SX fastback: #23 DSP/RallyMod2/Track Slut
'95 BMW 540i 6 speed: Ultimate Commuting Machine
PFM Racing
www.solo2.org
www.midwest240sx.com
Rennen is offline   Reply With Quote
Old 01-31-2004, 01:06 PM   #2
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
nice work... this should be FAQ'ed
very usefull info
CoasTek240 is offline   Reply With Quote
Old 01-31-2004, 01:29 PM   #3
matlock
matlock is an unknown quantity at this point
Yes, really nice post. I am looking at suspension possibilities and this was quite helpful.
matlock is offline   Reply With Quote
Old 01-31-2004, 01:37 PM   #4
Rennen
Rennen's Avatar
nah, it shouldn't be FAQ'd. The prices probably change too much from time to time. Also, its not complete...
anyone know where to get KGMM springs!!!!
if the AGX's can handle that spring rate, that might be a good cheap alternative to coilovers
-Matt
PFM Racing
www.solo2.org
Old 01-31-2004, 11:55 PM   #5
Mr. Foully
Mr. Foully is an unknown quantity at this point
Have a little extra time on your hands, Rennen?
No, I'm not cracking wise, it really would take me two months to create that.
THX!!!
Clever, speed-related witicism ignoring the rules of fate, physics and common sense soon to be inserted here.
Mr. Foully is offline   Reply With Quote
Old 02-02-2004, 01:52 PM   #6
AutoRnD
AutoRnD's Avatar
AutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the rough
Send a message via AIM to AutoRnD
ok.. well i will post some info on the zeals then...
this info will be for the nissan s13 240sx... with us specs..
for all zeals
the front upper mounts are pillow ball type while as the rear are just aluminum rigid.. they are 6 way adjustable and very easy to see your adjustments..not a clicking system but actual number systems. all zeals shocks are monotube with either 42-46 mm piston sizing dependig on car...
first off.. there is the baseline
zeal b2 coilover.. their msrp is 1658 and you have a choice of either 6/5k spring rate for street or 8/7k spring rate for track.. the shell casing is spring type and is single height adjust by raising and lowering the spring seat lock. they run a Id60 basic spring
Zeal function b6 are 2142.00 and their springs rates are 6/5 or 8/7... they aresingle monotube with free div piston (go figure) the shell casing is chromoly coated steel and runs a id60 basic spring as well.. but these bad boi's are double adjustable.. like tein he or jic flta2
zeal Function V6 list for 2237.99 and they are also 6/5 or 8/7...they are identical to the s6 except that the front is inverted.
zeal function s6 list for 2500 and are also 6/5 or 8/7 but they use id60 swift springs which are supposed to be better than the basic..and the shell casing is all aluminum with double height adjust.
zeal function d list for 2600 and are 9/6 spring rates.. they use id60 swift springs .. front is inverted and the shell casing is chromoly coated steel front and rear is aluminum
Then The racer / Most expensive is the super function they list for 2720.00 and have a spring rate of 10/8k using id60 swift springs. They have pillow ball front and rear and are all aluminum but these are meant for track use only...
with all zeal products bought through a us distributor of endless usa
they come with a 1 yr warranty card.. the coilovers are already assembled and set to endless usa's recomended ride height. the coilovers if anything were to happen to them are rebuilt in the usa.. and can be done very quickly ... ok that is all i have to say... without getting tooo biased cause i sell them...
www.AutoRnD.com
Nardi, Enkei, Stance, AME Master Distributors for USA
Check Out Our Facebook!
AutoRnD is offline   Reply With Quote
Old 02-02-2004, 04:00 PM   #7
s0ldats
s0ldats is on the path to ruins0ldats is on the path to ruin
awesome post
s0ldats is offline   Reply With Quote
Old 02-02-2004, 05:14 PM   #8
TougeRacing
TougeRacing's Avatar
TougeRacing has a little shameless behavior in the past
ohh that was some nice info thanx a lot
TougeRacing is offline   Reply With Quote
Old 02-02-2004, 05:56 PM   #9
AutoRnD
AutoRnD's Avatar
well i really cant see the pdf file... so i dont know what to include and what to exclude...
www.AutoRnD.com
Old 02-02-2004, 06:12 PM   #10
Rennen
Rennen's Avatar
Josh, thanks a lot for the great info. Can't see the pdf file? hmm, well its just the coilover type, spring rate, and dampening adjustability in a simple excell chart, then it has all the vendors I could find, and their prices. Most of the coilovers are in my list are in the sub $1600 range, so most of Zeal's line is too hardcore for me. BTW, does your company have a website? The only other vendor I could find for Zeal coilovers was raretrick.
Anyone have info on A'pexi Worldsport or N1 coilovers, or HKS's Hypermax? Those seem to be comparable in price. Also, I am still trying to find a place stateside that sells KGMM brand springs, seems all the places that used to don't exist anymore.
I updated the chart with the Zeal info from Josh, I will post an updated one later when I can get some more data.
-Matt
PFM Racing
www.solo2.org
Old 02-03-2004, 11:29 AM   #11
AutoRnD
AutoRnD's Avatar
well.. if skr is still open then they sell kgmm springs.. but we can get the kg/mm springs as well... just not a big seller for us.. but skrperformance.com and they are located in delran nj i believe...
we are located in milpitas.. and we are a wholesaler/ distributor.. also.. as of right now our website is being created.. hopefully it will be up relatively shortly...
www.AutoRnD.com
