Old 01-31-2004, 08:16 PM   #1
SkylineDriven
SkylineDriven is an unknown quantity at this point
Send a message via AIM to SkylineDriven
Clunking from under car
I just installed subframe collars and went to test it out... I'm noticing alot of clunking types of sounds now.... maybe the sounds were dampened by the stuck rubber subframe thingies, but I guess using the spacers just made all the sounds more apparent... I know that I installed them correct. Those suckers are in there TIGHT now. I even tried retightening them after I drove it.
When I jack up the rear differential and lower it, there is more or less no visible movement where the collars are.
Do the collars add more noise? Or is it being solid just finally unmasking what problems existed before (soundwise).... Let me describe what its doing.
When there is torquing and untorquing through the drive train (gas in, gas out) I hear a clunk/thunk... kinda like if someone had a rubber mallet and just hit something... it is coming from the rear..... also if I just rapidly tap the gas VERY lightly... kinda like if you tap your foot on the floor to the beat of music, but just doing the same motion on the gas pedal... you can hear it clunk with the rythm of your tapping.... and mind you, this is VERY light tapping. Enough to get some gas out, but not enough to change your acceleration.
And now also I notice that occasionally, even shifting through the gears will produce that clunking sound. I'm thinking that its coming from the transmission or something but I dunno... maybe tranmission mount? Or something inside the transmission itself? Or I dunno... what do you guys think? I think I have described it in pretty good detail.
TractionOptional (dot) com
SkylineDriven is offline   Reply With Quote
Old 01-31-2004, 10:58 PM   #2
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
The clunk is the spacers themselves. You have metal to metal contact now. When the backend squats, it's squatting on to an unpliable subframe spacer making the clunk you are hearing. Don't worry about it. You get used to it.
Flybert is offline   Reply With Quote
Old 02-01-2004, 12:58 AM   #3
holisticbeatz
holisticbeatz's Avatar
holisticbeatz is a well-known jackass
How strange, the reason why I installed subframe spacers was because of clunking noises.
Trust and I don't mean GReddy.
holisticbeatz is offline   Reply With Quote
Old 02-01-2004, 10:39 PM   #4
VitaminT
GhettoBoost
VitaminT is making a name for him/her selfVitaminT is making a name for him/her selfVitaminT is making a name for him/her self
If you have an aftermarket exhaust it could be it hitting the tunnel under the car. After I installed my 3" Greddy it did that until I did some adjusting.
VitaminT is offline   Reply With Quote
Old 02-01-2004, 10:50 PM   #5
SkylineDriven
I had rookie2nr drive my car today... he doesn't hear the clunking... my exhuast does vibrate alot tho.. i found where its hitting but still cant seem to do anything about it. i guess tis something i'll have to deal with. and maybe the clunking is just wahat everyone has been telling me.. cuz the spacers are metal... but i think il get poly bushings tho.. to see if that helps.
