![]() Join Date: Feb 2002
Trader Rating: (29)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 29 reviews
Enjuku Racing - GTX2860R ** IN STOCK **
Just Released!!
Garrett GTX2860R ** IN STOCK ** ![]() ![]() ![]() Garrett GTX2860R Turbocharger - Enjuku Racing Parts, LLC New GTX2860R dual ball bearing turbo with ultra high flow compressor wheel featuring Garrett 11-Blade technology . **Turbine Housing is sold separately and is the same as one used on GT2860RS using 53.86mm 76 trim turbine wheel. GTX turbos use same turbine housing as GT turbos and turbine housings are sold separately. The external dimensions of this turbo is the same as a GT2860RS so no changes in the engine bay is required in order to fit this turbo in its place. This GTX model also uses all the same oil and coolant fittings at the standard GT28/GT30R/GT35R turbo.** Compressor housing is GT28 style with 3" inlet and 2" outlet but has built in anti-surge machining. *** Actuator and bracket sold separately **
Office: 352-241-8399 / 1-888-SR20DET (772-0338) YouTube.com/c/EnjukuRacingParts http://www.enjukuracing.com [email protected] ![]() |
