Old 05-15-2012, 08:54 AM   #1
91300zxttkid
91300zxttkid is an unknown quantity at this point
BUILT RB25 300ZX PROJECT PARTOUT*tubular manifold*Comp TBB*GReddy*NEW 300ZX PERFORMAN
I hate to do this.. But i have to part out my build due to financial reasons..
S1 RB25
-Custom Aluminum oil pan made from 6061 aluminum for 300zx stock sway bar and NOT cutting the subframe at all.
-ARP Main and Head studs
-ACL Race main and rod bearings
-Wider oil pump drive collar machined on the crank.
-New N1 Oil pump
-Eagle rods
-CP Pistons .40 OB
-Cosworth multilayer headgasket
-Port and polished head
-3 angle valve job and all seats re-cut
-Supertech valvesprings and Ti retainers
-Triton valve steam seals
-RB20 cams
-GReddy adjustable intake and exhaust cam gears
-GReddy timing belt
-New NISSAN Idler and tensioner pullys with new stud.
-Illusion Purple powder coated covers with -10AN fittings welded on.
Current condition of the engine
For the Engine LONGBLOCK NO MANIFOLDS $5500.00
Tubular T4 twin 38mm dump manifold with NO TIAL GATES $1300 plus shipping
COMP TURBO CT4 6754 Triple ball bearing, T4 3 inch vband 750HP TURBO polished housing $1000 plus shipping NEW NEW NEW
Intake manifold with velocity stacks inside, cut and shortened, and powder coated mirror black $800 plus shipping.
Transmission with Z32 tail section, RB26 bell housing, GTR internals
$1200
Stock RB25 Flywheel with OEM bolts $60 shipped
DXD Southbend STAGE 6 6puck sprung hub clutch with 2200lb pressure plate, good for 800 hp Made for 300ZX and for RB NEW!
$800 plus shipping
EP Racing Once piece driveshaft NEW NEW NEW for TT 2+0 $210 SHIPPED
Powertrix RACING coilovers used for 1000 miles missing some top green caps.. work great!
$1000 plus shipping
Powertrix rear upper control arms.. $180 shipped
TIEN front adjustable tension rods
$160 shipped
Oil cooler kit with lines/fittings and Thermostat controlled sandwhich plate with fitting..
$350.00
Powerhouse Racing 8AN fuel rail with BRAND NEW Injector Dynamics 1000cc injectors $900 plus shipping
Tial 38mm MVS Vband wastegates in Red, I have 2 NEW NEW NEW
$250.00 each
Tial 50mm BOV in red NEW NEW
$200 plus shipping
txt or EMAIL ME FOR FASTEST RESPONCE.. VERY MOTIVATED SELLER, I CAN SEND PICS.. WORK OUT DEALS.. DRIVE TO MEET PEOPLE HALFWAY FOR THE ENGINE OR BIG THINGS..
I have more that is not listed on here.. Just ask..
Thanks!!
-George
Fully built RB25 Z32 300ZX coming soon!!
COMP TBB,twin tial gates..
91300zxttkid is offline   Reply With Quote
