Cosmetic HeadGasket
Ok so a friend told me these gaskets didn't seal very well.
has anyone ever used one and what were the results leme know please thanks |
Thats actually the requirement if you want it to seal properly. |
#5 | |
kouki man
![]() Join Date: Apr 2006
Trader Rating: (36)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 36 reviews
like he said. metal headgasket wont forgive any perfections from the surface. it is adviceable to get the surface milled have a flat surface. if you want it to seal properly you can try to use a copper spray gasket maker and decked it. |
#8 |
Alright thanks guys im gonna check the surface of the head and block..
Not wanting to pull the block just to resurface it, how well does this copper spray seal? I had a metal head gasket on before replacing because i read shit numbers on compression test.. cyl#1 30.. the other 3 150 just gonna switch gaskets and see if it fixes my problem |
#9 |
![]() Join Date: Jul 2008
Trader Rating: (32)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 32 reviews
I've had 2 cosworths..never resurfaced block, just the head. No problems. (Using copper spray) I actully reused one in my motor and later ended up making 400whp..of course I don't own the car anymore so don't know how the motor is doing.
#10 | |
do you know any difference in the two gaskets like what would make one better than the other |
#14 | |
Man w/ CTSV & a Car Seat
#15 | |
![]() Join Date: Jun 2003
Trader Rating: (130)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 130 reviews
#16 |
To be honest, I've had two cometic head gaskets and both of them were blewn on my KA, but I can't blame them because I never resurfaced the block and I think it also had to do with the tune(timing). Know I resurfaced both and did firerings to the block also. I'm gonna try it for the last time with the cometic if I have problems again then f** it lol. As soon as I finish with my rebuild and retune I'll let you guys know.
IG: chris___s14 |
#19 | ||
#20 |
Because before the first time it happened the car overheated in the break in, but then the car was good and I dynoed it with 33 passes and did 404hp, after that the car was still perfect. Then when I tried in the street draging with two cars from 1st to 4rth gear it blew it. So I though it was by cause of it because after it when I was rebuilding it the head was very bad, so I resurfaced it, but I didn't resurface the block. I finish rebuilding, I break in it, then at dyno when the tuner is working with the timing in one pass it blew it again when reaching 368hp. When I was rebuilding it I noticed that the first pinston had the compresion rings sticked inside it and the rod was purple at the top and the piston had shrunk a lil bit. Non of my friends ever had problems with cometics and they always use them. One of them has a KA-T with 550hp and the other one has an SR with 600hp, and everyone else has high hp also and still no issues.
IG: chris___s14 |
