Old 02-09-2004, 11:18 PM   #1
XxJaPxOxNeEs23xX
XxJaPxOxNeEs23xX's Avatar
XxJaPxOxNeEs23xX is making a name for him/her selfXxJaPxOxNeEs23xX is making a name for him/her self
Send a message via AIM to XxJaPxOxNeEs23xX
i dont get this output flanges stuff.
i read in other forums about the output flanges and how s14 vlsd flanges and the s14 open diff flangs are differnt. but i dont know if the s14 vlsd flanges will fit in the s15 hlsds. if it was to, how much can i buy and were can i buy the s14 vlsd flangs. also does the s15 hlsd fit in the housing of a s14 open diff????
XxJaPxOxNeEs23xX is offline   Reply With Quote
Old 02-09-2004, 11:47 PM   #2
thelinja
thelinja's Avatar
thelinja is making a name for him/her selfthelinja is making a name for him/her self
VLSD output shaft spline pattern is different from from open diff output shaft spline pattern, as is HLSD output shaft spline pattern. None of the three are interchangeable as far as I know. S15 HLSD fits into R200 diff assembly. Here's a pic of my pumpkin after putting the HLSD in.
thelinja is offline   Reply With Quote
Old 02-10-2004, 12:07 AM   #3
BadMoJo
BadMoJo's Avatar
BadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura about
Send a message via AIM to BadMoJo
Which output shafts did you use?
----Gone----
BadMoJo is offline   Reply With Quote
Old 02-10-2004, 07:58 AM   #4
thelinja
thelinja's Avatar
S15 ouput shafts that came with the S15 diff
Old 02-10-2004, 12:19 PM   #5
XxJaPxOxNeEs23xX
if u hav a s14 open diff or vlsd is it still called a r200?? cuz i hav open diff nd i dont know if the s15 diff will fit in it.
Old 02-10-2004, 06:35 PM   #6
BadMoJo
BadMoJo's Avatar
yeah its an r200. The s15 HLSD will fit inside the open diff housing, you just need to use the S15 output shafts.
"thelinja" did a small "how to" write up in a thread recently. Just do a search for S15 HLSD.
----Gone----
Old 02-11-2004, 12:39 AM   #7
haveblue
haveblue's Avatar
haveblue is an unknown quantity at this point
Send a message via AIM to haveblue
what pattern are the s15 output shaft flanges?
haveblue is offline   Reply With Quote
Old 02-11-2004, 01:28 PM   #8
XxJaPxOxNeEs23xX
is there any car in the us that hav the same output shaft as the s15's???
Old 02-11-2004, 03:25 PM   #9
thelinja
thelinja's Avatar
No, the ONLY output shafts that work with the S15 HELICAL DIFFERENTIAL are shafts that were used on an S15 Silvia (not sure if it was just Spec R) with said differential.
