![]() so i drove my car to work when suddenly it shut down... all my fuses blew up n the harness over the driver side tire well was scraping my tire n became exposed an they all touch n shorted out my car i fix the wires and the fuses but car now cranks but doesnt turn on... plz help!! :/
try swapping in another ecu or recheck your wiring. maybe something got wired wrong. i had a similiar harness problem which required new wiring and new relays. good luck. if you get still get stumped i recommend jordaninnovations located in irwindale.
yeah i thought it was going to be the wiring so i double check every connection by the way none of the wires ever separated jst got really worn n dirty so i cut n replace with new wire one by one so i wouldnt get them confused .. how would you be able to test the compter with out swaping it cuz none of my friends have one n the cheapest ive found was for 80 bucks n im kinda tight on money right now! :/
car wont start, ecu, ecu wont throw code |
