Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 06-13-2012, 02:08 PM   #1
13esim
13esim's Avatar
13esim is an unknown quantity at this point
Help: Z32 wont turn all the way to the right
My z turns 360 degrees to the right and about 585 degrees to the left. What would cause that. Gearbox? If so how would I access it and what tools would I need? Kind of a moon with working on cars. I'm 17 and have limited resources, but I want to learn.
13esim is offline   Reply With Quote
Old 08-11-2012, 09:41 AM   #2
Chaluska
Chaluska is an unknown quantity at this point
a really jacked up steering rack, or mis-alignment
Chaluska is offline   Reply With Quote
Old 09-27-2012, 04:44 PM   #3
MalditoJay
MalditoJay's Avatar
MalditoJay is an unknown quantity at this point
Your caster could be really off, or steering rack could have took a crap on you. Not sure, good luck with that.
MalditoJay is offline   Reply With Quote
Old 09-27-2012, 05:10 PM   #4
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
take it to an alignment shop. the tie rods are probably unequal length in adjustment. they would have to center the rack by making sure steering wheel turns the same amount left to right and right to left. then adjust the toe. they would probably have to remove the steering wheel to get it close to center, then adjust the toe again.
rcdad123 is offline   Reply With Quote
Old 10-03-2012, 01:07 AM   #5
Chronox2
Chronox2's Avatar
Chronox2 is an unknown quantity at this point
Does it drive straight if you let go the steering wheel? Whe you start turning do you feel a delay? Does it turn at all or a bit more after that point? Fluids? Have you gone under the car to make sure there is nothing jammed?
Chronox2 is offline   Reply With Quote
Old 10-03-2012, 06:36 AM   #6
silviaNC
silviaNC's Avatar
silviaNC is an unknown quantity at this point
Sounds like your steering rack is not centered. Had that problem on my wife's maxima after they replaced the steering rack.
silviaNC is offline   Reply With Quote
