ka24de - T Vacuum routing help.
So I am in the process of piecing all of my turbo parts together. Will be using a stock t25 with an isis bottom mount manifold. Will be getting the isis bottom mount fmic kit from enjuku. Now my problem is figuring out the vacuum routing. Should i leave a lot of things routed like they are i.e (iacv, random stuff on the intake manifold that would usually require vacuum to operate) or run reroute them to the compressor piping behind the maf so they are pulling vacuum that way? Also should I route my aftermarket fuel pressure normally or into the compressor side. Im already planning to delete my PCV on the bottom of the intake manifold and cap the holes.
INPUT please. thanks.
"Man who stand on toilet, high on pot" Confucious
