Old 06-14-2012, 09:29 PM   #1
violak90
violak90's Avatar
violak90 is an unknown quantity at this point
s13 KA24de Check engine light
I was given a few codes...EGR - there was clogged ports and a kinked hose; cleaned ports/intake, replaced hose.
MAF- replaced MAF
Knock - damaged wire from harness to sensor - replaced sub harness.
Replaced Cat (was at 36% efficiency)
Engine light only comes on at around 2500 RPM, normally when on freeway, and goes off when i get off freeway...tried to pull code from ECU, can't get one...
Any ideas?
Thanks.
violak90 is offline   Reply With Quote
