Old 06-21-2012, 05:55 PM   #1
Thatsoverated101
Thatsoverated101 is an unknown quantity at this point
My rb25 isn't running right
Ok I'm brand new to this forum and to the rb family but here's what I have so far. 1989 240 with stock rb25 with Cx racing turbo, 550 deutch works injectors, walbro 255, apexi power fc. Now here's the problem. I just put the rb in this past week and upon first start up it was running rough. I pulled all the plugs and replaced them and it ran z little better but still not perfect. You can only tell its running bad once you give it some throttle and it stutters, so I started checking coils to see if it was spark related. Now here's where it gets Wierd. All the coil packs are good and are giving off good spark, but I can disconnect the 5 and 6th cylinder coils and the car runs exactly the same. There is no smoke at all from the exhaust like youd expect from unburnt feul. Any ideas????
Thatsoverated101 is offline   Reply With Quote
Old 06-21-2012, 07:03 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Did you get the PFC set for the 550cc injectors?
CLICK HERE!!!
Old 06-21-2012, 07:22 PM   #3
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
check all your pin connections at the ecu. When i first got mine running cyl 1 wasnt cutting whenever i disconnected the injector. Continuity checked good all the way from the injector connector to the ecu. It turned out to be the pin being a little rusty at the ecu making a bad contact. cleaned everything up and ran suave after that. gl
feito is offline   Reply With Quote
Old 06-21-2012, 08:19 PM   #4
Thatsoverated101
I figured it out. So this one falls under never trust your friends to help you work on a car lol. I had asked him to connect the clips on top of the injectors and the two closest to the firewall weren't clipped on. I clipped them on and other than a small vacume leak she runs great untill it heats up. The clip for my ox sensor is broken so I need a diagram of what the three wires are that come out of the sensor itself. I know ones ground ones power and ones signal but there are two white wires and one black. I just need a diagram of which is which( besides the obviouse ground )
