Old 06-24-2012, 03:26 PM   #1
victormak91
victormak91 is an unknown quantity at this point
240sx s14 start up problem injectors??
hi, i have a s14 obd2 with a cold start problem. I would have to press the gas pedal down to start the car. When it is cold out, it would take me extra long to start and i can hear the engine trying to catch on but still dont start. I would also hear pops coming from the engine like backfire in the downpipe, then the motor would rock around a bit like it wants to start.
When the engine is warm, and shut off. If i try to start up the car it would start then die quickly. I ALWAYs have to press a lil gas to start the car
Is this a injector problem?? like flooding the engine?
I checked the codes n i only have 2 stored codes that is knocks sensor and car running to rich, i have cleared the codes for 6 months now and havent came up.
I also have this problem where the car rpm would bounce 1 time like a rev limitor and lose a mili second of power usually when i hit a bump on the road. But sometimes on a bad day, my car rpm would bounce around jerking the car violently when i try to take off or just cruisin. But this doesnt occur that much.
I replaced the cap n rotors, spark plug wires, coolant temp sensor, fuel pump, fuel filter, iavc.
I was wondering is my injectors leaking? or is it my knock sensor wire or some kind of wire that is loose?? eletrical problem?? bad ground?? plugged egr?? or any ideas?? i have had this problem since i got this car and yes i did search
victormak91 is offline   Reply With Quote
Old 06-24-2012, 06:42 PM   #2
haxoraxe
haxoraxe's Avatar
haxoraxe is an unknown quantity at this point
bump, having same problem
haxoraxe is offline   Reply With Quote
Old 07-01-2012, 05:54 PM   #3
victormak91
bump still havent figured out the problem
Old 07-03-2012, 12:53 PM   #4
ka4life87
ka4life87 is an unknown quantity at this point
Possibly leaking injectors, done fuel pressure test yet?
ka4life87 is offline   Reply With Quote
Old 07-03-2012, 05:20 PM   #5
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
is it a ka or sr? if it's an sr then you probably don't have the cold start hooked up properly.
godsmack is offline   Reply With Quote
Old 07-30-2012, 12:47 PM   #6
victormak91
its a ka24de..problem getting worse,
s14, starting problem
