Old 06-26-2012, 07:53 PM   #1
Southern Elegance
Southern Elegance is an unknown quantity at this point
Rear caliper locking???
anytime i drive the car for over 5 minutes and use the brakes the driver side rear caliper wont release so it constantly slows the car down. i already replaced the caliper with a new one, re-bled the system, and blocked off the vacuum to the brake booster to check it but i still cant figure it out. PLZ help!!!
Southern Elegance is offline   Reply With Quote
Old 06-26-2012, 08:04 PM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Slide pins. Take them out, clean them up, re-grease them.
Old 06-26-2012, 08:05 PM   #3
Southern Elegance
already replaced and greased them
Old 06-26-2012, 08:11 PM   #4
KiLLeR2001
Trader Rating: (46)
You might have to remove the splitter in the rear that splits the hydraulic fluid to both rear calipers, see if that is blocked at all. This is assuming the caliper you are working with is fully functional and you can verify that the slide pins are moving in and out with ease.
Old 06-26-2012, 08:30 PM   #5
Southern Elegance
I'll remove the splitter and lines this weekend, what should i use to clean them i don't want to contaminate the lines? Hopefully i get some where this is starting to piss me off
