Old 07-02-2012, 01:54 PM   #1
c-los13
c-los13's Avatar
c-los13 is an unknown quantity at this point
Dedicated relay on s13
I just got an email from Martin (Enthalphy RS, btw awesome guy) saying that i need to run a "dedicated relay for my fuel pump"
i did some research and found old articles.
anybody got any info on this?
s13 sr20det
c-los13 is offline   Reply With Quote
Old 07-02-2012, 01:59 PM   #2
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
google "fuel pump hard wire"
lok is offline   Reply With Quote
Old 07-02-2012, 02:30 PM   #3
intel5811
intel5811's Avatar
intel5811 is an unknown quantity at this point
You mean you put a sr in an sr and someone told you to run a separate relayed line to make your fuel pump work?????
intel5811 is offline   Reply With Quote
Old 07-02-2012, 06:03 PM   #4
c-los13
c-los13's Avatar
ive had my sr running for a while with a walbro fuel pump and it worked fine,idk why Martin said to run a "dedicated relay"
im runnning race gas on my second tune maybe thats why
Old 07-02-2012, 06:07 PM   #5
Memberofthe600hpkaclub
Memberofthe600hpkaclub's Avatar
Memberofthe600hpkaclub is an unknown quantity at this point
Because that wiring is getting old...and its better safe then sorry
Memberofthe600hpkaclub is offline   Reply With Quote
Old 07-02-2012, 06:10 PM   #6
c-los13
c-los13's Avatar
i really appreciate everybodys input
Old 07-02-2012, 06:38 PM   #7
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
most of the time the old wiring doesn't provide enough power to the pump, when you relay the fuel pump directly from the battery you reduce the chance of the pump not having enough power, it's a simple and cheap mod. Maybe he doesn't want you to risk not having enough power to the pump and damage your engine with the tune since he does his tunes with the idea that the car is under good conditions...
Originally Posted by Taniguchi_Is_#1 View Post
...this is zilvia; prepare to get your feelings hurt.
bejota180sx is offline   Reply With Quote
Old 07-02-2012, 06:39 PM   #8
c-los13
c-los13's Avatar
ok i understand,ima do this mod before installing the ecu!
thanks!
Old 07-02-2012, 11:21 PM   #9
cotbu
cotbu's Avatar
This is one of the mods, every swap should have done!
If you have problems or question's, I watching!
Is this a race car or street car?
Old 07-23-2012, 09:13 PM   #10
c-los13
c-los13's Avatar
street car
pump has been working fine
didnt need this dedicated relay after all
im still gonna install one soon to prevent future problems
Old 07-24-2012, 03:07 AM   #11
Croustibat
you already have a relay, it is commanded by the ECU. What you need is replace the thin cables by thicker cables.
Old 07-24-2012, 07:28 AM   #12
cotbu
cotbu's Avatar
I'm sure he means hot wire mod for the fuel pump! "dedicated relay" is being used like the terms "limp mode" or "bogging"!
