Old 07-06-2012, 09:05 PM   #1
appleburger
appleburger's Avatar
appleburger is an unknown quantity at this point
Weird starter issue, help!
No turning over, no click, no nothing. S13 KADE, stock wiring, stock ECU. Battery is tested and charged, tried two different starters both known to be good one is even straight out of the box brand new. I've tested the leads and verified one is getting a constant 12v while the other gets 12v when the key is turned. I don't understand how it's not working when I know the starter & battery are good and have verified the leads to the starter are getting signal.
http://i27.tinypic.com/otnl8j.jpg
appleburger is offline   Reply With Quote
Old 07-06-2012, 11:33 PM   #2
1ZlowZ
1ZlowZ's Avatar
1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute1ZlowZ has a reputation beyond repute
possibly bad starter solenoid.
I'd start with that.
-Victor S.
1ZlowZ is offline   Reply With Quote
Old 07-06-2012, 11:54 PM   #3
gerardogomez0809
gerardogomez0809's Avatar
gerardogomez0809 is an unknown quantity at this point
That is very possible but since he says he bought the starters brand new they should of came with new solenoids. If u turn the key and u don't hear the gear drive engage or any type of noise coming out of the starter it has to be a bad wire, might of gotten pinched or something. Trace your wiring, I know the 240's have two starter ignition wires. Let us know what u find. What brand are the starters you bought?
Sent from my iPad using Tapatalk HD
gerardogomez0809 is offline   Reply With Quote
Old 07-07-2012, 12:18 AM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Could be a bad ignition cylinder...my shit would do that every so often. Turn the key, it doesnt send the signal to the starter so nothing happens.
CLICK HERE!!!
Old 07-07-2012, 04:11 PM   #5
appleburger
The one that's new is an acdelco, the other was hooked up to a machine at autozone and verified the solenoid is working properly.
What's weird is that by testing the ignition wire at the starter with a voltmeter I know it's getting signal when the key is turned. It doesn't make any sense.
Old 07-07-2012, 04:27 PM   #6
gerardogomez0809
That is weird. When I installed my viper alarm with remote start, I had the same problem. Everything would turn on except the starter, no engaging whatsoever. That's when I noticed that our cars had two starter wires. I had tapped into the one that controlled all of my accessories. The one I had to tap into is the one I had connected to my turbo timer. It was a pain in the a$$ trying to figure it out
Old 07-07-2012, 04:43 PM   #7
Taylor008
Taylor008 is an unknown quantity at this point
Motor grounded?
Taylor008 is offline   Reply With Quote
Old 07-08-2012, 10:04 AM   #8
lighter
lighter is an unknown quantity at this point
could check the wire that connects to the starter, tend to come loose every now and then
lighter is offline   Reply With Quote
Old 07-08-2012, 11:24 AM   #9
r20crazy
r20crazy's Avatar
Trader Rating: (41)
r20crazy is an unknown quantity at this point
Feedback Score: 41 reviews
check the starter cutout switch on the clutch pedal if ur car is a factory manual. if ur a conversion u dont have this circuit. on the clutch pedal if the rubber 'stopper' on the clutch pedal is missing and not disengaging the cutout switch when clutch pedal is pressed down car will not start. if missing you can tape a couple pennys to it or put a bolt/nut into the existing hole. the switch may also be bad, try jumping the switch by disconnecting it and jumpering the harness wires. again this is only valid if originally a manual trans car. hope this info helps
Originally Posted by Your240sucks;
Dont really want to lowball you but Will you pay me too pick it up?
r20crazy is offline   Reply With Quote
Old 07-08-2012, 03:12 PM   #10
appleburger
Thanks for the tips!
It was originally an auto sohc but has been running dohc/5spd for years without issues.
When we jumper it straight to the battery it works just fine. It seems like the ignition circuit is hosed but that's contradicted by the fact the starter ignition lead is getting the 12v it should when the key is turned. I'm baffled.
Old 07-09-2012, 01:13 AM   #11
Taylor008
Where are you getting that voltage? At the ignition switch or the starter?
Old 07-09-2012, 07:29 AM   #12
appleburger
At the connector that plugs into the ignition lead at the starter
