Old 07-10-2012, 09:21 PM   #1
Trixunlimited
Trixunlimited is an unknown quantity at this point
car bogging down low/stalling when hot need help
I just picked up a 89 nissan 240sx that ran good when I bought it but seemed to have a slight bog only when the car was hot/or after i drove moderately hard. After a couple of days the bog got worse so now i had to give the car about 1/20th throttle from a stop just to keep the car from bogging but after the car is moving it is fine. I was like ok let me change some stuff and after all the changes i list now(, spark plugs, wires, cap, rotor, fuel filter, fuel pump,) nothing has gotten better
So my next ideas were 02 sensor/ignition coil/maf sensor.
Any help is welcome I just cannot seem to figure out the issue. But like I said when the car is cold it runs good but when its hot it acts like doo doo butter and even idles bad.
Trixunlimited is offline   Reply With Quote
Old 07-10-2012, 09:22 PM   #2
Trixunlimited
Or even injectors but I do not think they would get worse over time with heat issues i dunno
Old 07-11-2012, 05:17 AM   #3
Trixunlimited
Bueler anyone
Old 07-11-2012, 09:51 AM   #4
Trixunlimited
Changing the oxygen sensor and the ignition coil now, otherwise the last two things are injectors and maf
Old 07-11-2012, 09:54 AM   #5
Trixunlimited
This is also on a stock ka sohc, automatic.
Old 07-11-2012, 06:13 PM   #6
Chugpuppy
Chugpuppy is an unknown quantity at this point
take a look at my thread, see if it's similar to your problem:
http://zilvia.net/f/tech-talk/463937...hing-idle.html
Chugpuppy is offline   Reply With Quote
Old 07-12-2012, 11:35 PM   #7
s13drob
s13drob's Avatar
Trader Rating: (29)
s13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymore
Feedback Score: 29 reviews
Check the base idle and base timing. I bet your base idle is too low and wouldnt hurt to check the timing for the poor performance. This is for KA24DE, but i think its the same procedure.
KA-T.org - The Home of 1000+ whp/7 sec Turbo KA's
s13drob is offline   Reply With Quote
