Old 07-12-2012, 12:16 PM   #1
Coolwhip
Coolwhip's Avatar
Coolwhip is an unknown quantity at this point
Send a message via AIM to Coolwhip
RB Raw Brokerage - Blue 700hp RB26 Build Thread
Hey guys,
Figured I would make a thread to share some of our recent work we've done for a customer that had a 700hp RB26 requirement. He wanted a show ready motor that could take daily abuse. On with the pictures...
The wide body R33 GTR rolling on VS-XX's that we're building it for:
We started from an already mildly built long block we had shelved to begin tear down:
The bottom end will be equipped with the following:
OEM R33 Crankshaft - Extended crank collar version
CP Pistons - CP Forged RB26DETT Piston Kit - Raw Brokerage - Your #1 source for GTR and RB parts!
Carrillo Connecting Rods with 3/8" CARR Rod Bolts - Carrillo PRO-H Beam Rods - RB25/RB26 - Raw Brokerage - Your #1 source for GTR and RB parts!
ARP Main Studs - ARP Main Stud Kit - RB20 / RB25 / RB26 / RB30
ACL Rod Bearings - ACL Race Series Rod Bearing Set - RB30
ACL Main Bearings - ACL Race Series Main Bearing Set - RB26DETT
The RB26 cylinder head was also prepared with goodies:
Bronze valve guides
Tomei Type-B Valve Springs - Tomei RB26DETT Valve Springs
Tomei Type-B Poncams - Tomei RB26DETT Poncams
ARP Head Studs - ARP RB26 Head Stud Kit - Raw Brokerage - Your #1 source for GTR and RB parts!
A few other modifications including: Tomei Oil Pump, N1 Water Pump, Tomei Timing Belt, Tomei adjustable cam gears, Metal head gasket, etc... we're used to complete the long block assembly:
A race ready 1500hp Ross Tuffbond Harmonic Balancer was fitted to the front as well:
Ross Tuffbond Metal Jacket RB26DETT Harmonic Balancer
The oil pan was modified using our extended sump kit for the RB26 oil pans:
Raw Brokerage RB26 AWD Enlarged Oil Pan Service - Raw Brokerage - Your #1 source for GTR and RB parts!
To start dolling up the motor we powder coated the valve covers to match the rest of the engine accents and keep the theme of the car...
Mine's baffles:
Raw Brokerage center plate to top off the coil pack cover:
Raw Brokerage RB26 Valve Cover Emblem
Next up... turbo and fuel
Coolwhip is offline   Reply With Quote
Old 07-16-2012, 01:18 PM   #2
Tle1993
Tle1993's Avatar
Tle1993 is an unknown quantity at this point
damm this shit is bad asss!
Tle1993 is offline   Reply With Quote
Old 07-16-2012, 01:27 PM   #3
tricky_ab
tricky_ab's Avatar
The rear of that GTR looks awful, but I'm down for a RB build
Old 07-16-2012, 06:57 PM   #4
208s14.5
208s14.5 is an unknown quantity at this point
is this johns r33?
208s14.5 is offline   Reply With Quote
Old 07-16-2012, 07:05 PM   #5
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
awesome start to a build thread! keep the updates coming!
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 07-16-2012, 07:28 PM   #6
Kingbaby
Kingbaby's Avatar
Kingbaby is an unknown quantity at this point
+1
in for engine build
#0191 "Lin'da" 2AMR>2AMR>
Originally Posted by Bambi View Post
That's pretty cool. Never sell it, you'll regret it.
Originally Posted by thisisastickup View Post
I donut see an FC on this page, man
Kingbaby is offline   Reply With Quote
Old 07-16-2012, 07:57 PM   #7
K_shan
K_shan is an unknown quantity at this point
I'll be seeing the motor in person tomorrow when it Arrives at my home.
Btw I'm the one building the car for john. I chose RAW for the motor and parts supplier because they have a great reputation and even better products.
K_shan is offline   Reply With Quote
Old 07-17-2012, 05:54 AM   #8
Coolwhip
Coolwhip's Avatar
Originally Posted by 208s14.5 View Post
is this johns r33?
It is.
Kevin, thanks for the kind feedback and again to you guys for giving us the opportunity to build the motor
I'll make an update post in a bit
Old 07-17-2012, 06:25 AM   #9
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
sick build.....in for more updates
2muchboost is offline   Reply With Quote
Old 07-17-2012, 06:45 AM   #10
Coolwhip
Coolwhip's Avatar
To achieve the power goals desired the route chosen was to ditch the twin turbo setup and go with a single turbo manifold...
Full Race ProStreet Twinscroll Top Mount Response Manifold - Raw Brokerage - Your #1 source for GTR and RB parts!
I know you guys are going to ask, "why didn't we use our in-house manifold?" Well simply put we were in on a time crunch and the recent changes to our manifold design wasn't going to allow us to have it ready and tested for delivery. Since we had Full-Race manifolds in stock it was a no brainer
Well we sent the twin scroll manifold to our ceramic coater for some of his handy work... the ceramic coating is to keep the temps down in the engine bay, keep the exhaust heat inside the manifold for better performance, and for that oh so pretty finish
More fuel was required than the 440cc factory units so we turned to our injector of choice for these types of builds, the Injector Dynamics 2000cc injectors:
Injector Dynamics 2000cc Injectors - RB26DETT
As well, to get the fuel through the new 11mm injectors a twin feed Tomei fuel rail was an instant match:
Tomei Top Feed Fuel Rail - RB26DETT
With the machined hats and the precisely made rail....
and with those goodies installed to the motor...
Assembling the turbo and wastegate pics...
Old 07-17-2012, 08:39 AM   #11
cnile51
cnile51's Avatar
cnile51 can only hope to improve
Nice Build, can't wait to see what she puts down!
cnile51 is offline   Reply With Quote
Old 07-17-2012, 10:30 AM   #12
blo0d
blo0d is an unknown quantity at this point
this is top notch, keep the great work up guys
blo0d is offline   Reply With Quote
Old 07-22-2012, 11:21 PM   #13
NOOBdrifter
NOOBdrifter's Avatar
NOOBdrifter is an unknown quantity at this point
Any more updates on this?
NOOBdrifter is offline   Reply With Quote
Old 07-23-2012, 11:28 AM   #14
drscooper
drscooper is an unknown quantity at this point
dang this thing is sweet more updatess!
drscooper is offline   Reply With Quote
Old 07-26-2012, 08:19 AM   #15
Coolwhip
Coolwhip's Avatar
Clear RB26 NITTO Cover to show up the goodies spinning behind the front covers:
Nitto RB26DETT Clear Timing Cover
Also center coil cover finished off with a Raw Brokerage garnish:
Installed are also twin blue TiAl MV-S wastegates and we ceramic coated the twin scroll T4 turbine housing of the billet series Precision 6466 turbocharger to suite the build:
For the intake side we converted the individual throttle bodies to our single throttle body plenum:
Raw Brokerage Pro-Flow Intake Plenum - RB26DETT
Photoshoot pics of the completed motor to come...
Old 07-26-2012, 09:59 AM   #16
mishimoto
mishimoto's Avatar
mishimoto is an unknown quantity at this point
Wow awesome build! In for dyno numbers and videos.
Mishimoto Automotive
mishimoto is offline   Reply With Quote
Old 07-26-2012, 10:05 AM   #17
drscooper
^^^^ with this guy! that engine is so dam beautiful!! great build!!
Old 07-26-2012, 10:09 AM   #18
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
Mother of god.
Legit.
onehundredoctane is offline   Reply With Quote
Old 07-30-2012, 06:08 PM   #19
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
wow what a gorgeous engine build! nice to see someone pony up the $$$ to have it done right!
Old 07-30-2012, 06:18 PM   #20
fckillerbee
fckillerbee's Avatar
holy fuck. I want to hear this thing spool!
Old 07-30-2012, 06:26 PM   #21
EjMalernee
EjMalernee's Avatar
EjMalernee is an unknown quantity at this point
nice build you guys. That motor is looking super sexy.
EjMalernee is offline   Reply With Quote
Old 07-30-2012, 06:51 PM   #22
dreamin240sx
dreamin240sx's Avatar
dreamin240sx is an unknown quantity at this point
Send a message via AIM to dreamin240sx
looks amazing just needs a new oil cap lol
RB POWA!!!!!!!!
dreamin240sx is offline   Reply With Quote
Old 08-03-2012, 06:26 PM   #23
Coolwhip
Coolwhip's Avatar
Desktop wallpaper for you guys of the finished product... (more to come)
Raw Brokerage - Desktop Wallpapers
Old 08-05-2012, 01:27 AM   #24
badfish816
badfish816 is an unknown quantity at this point
wow. thats pretty insane! definitely some good eye candy. i see it is you guy's banner on the website as well.
badfish816 is offline   Reply With Quote
Old 08-05-2012, 01:01 PM   #25
S14Serge
S14Serge's Avatar
S14Serge is an unknown quantity at this point
This build is just so epic!
S14Serge is offline   Reply With Quote
Old 08-05-2012, 01:58 PM   #26
Big Country Labs
Big Country Labs's Avatar
Big Country Labs is an unknown quantity at this point
beautiful. Nice work.
Big Country Labs is offline   Reply With Quote
Old 08-06-2012, 09:27 AM   #27
NOOBdrifter
I love this engine! :')
Old 08-07-2012, 08:23 PM   #28
GideonD1025
GideonD1025 is an unknown quantity at this point
Man i love RawBrokerage's builds and you guys seem to love the rb26 lol dont blame you guys. Love the build great work and that is a sexy R33
GideonD1025 is offline   Reply With Quote
Old 08-07-2012, 09:20 PM   #29
Imarvin240
Trader Rating: (18)
Gorgeous engine. Are you guys replacing the oil cap seems like everything is aftermarket/custom except that hah
Old 08-11-2012, 09:15 PM   #30
P-Funk alot
P-Funk alot's Avatar
P-Funk alot is an unknown quantity at this point
Send a message via Yahoo to P-Funk alot
is that my nijas flacos car in the back
P-Funk alot is offline   Reply With Quote
6466, r33, rawbrokerage, rb26, skyline
