Old 02-23-2004, 03:15 PM   #1
AN89HATCH
AN89HATCH is a well-known jackass
s13 How do i stop the hard shaking at idle 1989 240sx searched, but no help
I have an 89 s13, and at idle i can not get it to stop shaking, it shakes as if its an old school muscle car haha, and it will not keep a steady idle, it idles at 700, then drops to 600 then up to 750, and will keep doing the same thing over and over agin, as the idle moves thats when the car starts to shake. Any suggestions as to what the problem is? thanks
slide your ride.com
AN89HATCH is offline   Reply With Quote
Old 02-23-2004, 03:27 PM   #2
nrcooled
nrcooled's Avatar
nrcooled is an unknown quantity at this point
Send a message via Yahoo to nrcooled
Check all vacuum hoses and fittings. Clean out your throttle body along with making sure that your AIV valve is adjusted propperly.
If all of those check out then make sure that all your grounds are good
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP
nrcooled is offline   Reply With Quote
Old 02-23-2004, 04:01 PM   #3
Thieu
Thieu is an unknown quantity at this point
I've had the same problem for a while. I replaced the IIC, air regulator, all vacuum lines, took off the EGR, took off the AIV, and it still does it. Everything ignition related is recent, as well as a Z32 fuel filter. Next step is a new TPS, FPR, and Fuel pump.
90 240sx
daily driver/project car
"SOHC it to me"
Thieu is offline   Reply With Quote
