Lots For Sale, Manley, OS Geiken, ITB's, SPL
Need this stuff gone like yesterday!!!
Manley SR20 Connecting Rods N.I.B. rated for 800wtq- $300 BC Racing SR20 Nitride coated Int & Exh valves N.I.B.- $200 Supertech SR20 valve guides N.I.B.-$100 SR20 RWD Blacktop Complete Head, has had alot of maching work done, light P'n'P, decked, hot tanked etc, Toda 264 cams, Greddy valve springs, Tomei solid lifters and shims, circuit sports rocker arm stoppers, cam gears, valves and valve guides are stock, stock great condition valve cover included, less than 400miles on the setup and zero miles since it was resurfaced and cleaned, just needs the gap double checked on the lifters and torque down the cam caps to spec asking just $700 for it all Ichiba Alum Rad with Samco hoses in red- $140 GTi-R Individual Throttle Bodies, comes with TPS, plenumn and tank, vacuum canister, I can modify for RWD head, Huge jump in spool, flatter torque curve, and the best sounding SR int setup in my opinion-$200 SR20 RWD tranny, less than 1,100 miles since the rebuild, has O.S. Geiken 2nd, 3rd, and 4th upgraded gears for holding lots of trq, no grinds no kinks no whines, zero clutch kicks on it and no drifting at all just daily driving to break it in- has had alot of money and work put into it- $400 SR20 Power Steering setup, ps pump tig'd with AN fittings, power steering cooler and an alum power steering resevoir, all AN fittings and steel braided lines for the whole setup, asking just $120 for it all Mid Mound Intercooler, tube and fine designe 18" long x 2.25" thick x 6.25 tall with a 3" wide end tanks x 6.25" tall- $60 Blitz DD Bov less than 1,100 miles on it, comes with flange and pipe-$80 Apexi Metal Headgasket, stock bore and thickness, new but has been lightly copper coated- $60 SR20 Freddy baffled extra capacity oil pans, 1 new $60, I used $40 SR20 water pump with lightweight pulley- $40 SR20 lightweight water pump pulley- $20 SR20 crankshaft, great condition- $100 SPL outer tie rod ends w/ bumpsteer adjusters, S14 inner tie rod with slip on spacers and new dust boots-$120 Blitz carbon face 2" boost gauge, measures in BAR-$40 240sx Big Brake adapter brackets, uses z32 calipers with z33/g35 big rotors, includes bolts with brackets- $40 Z32 Maf with pigtail-$40 SR20 stock connecting rods-$40 SR20 upper and lower oil pans-$40 SR20 alternator with lightweight pulley- $40 SR20 starter- $20 SR20 Cam Angle Sensors- $20 SR20 coilpacks (4)- $40 for all 4 SR20 stock cams with stock cam gears- $60 tons more parts just ask I am willing to ship parts, I have alot more to post up and I will send all the pictures you need, Thanks Zilvia! |
#5 |
Post pictures of items forsale in your original post per forum rules. Interested in the rods, need pictures.
#24 |
well if he is ill take the trans, head, rods, valves, and maybe the gtir idividuals. pay pal ready will pay for shipping so pm me lets work out a deal. if your trying to sell
