*** SOLD *** 1990 S13 Coupe w/SR20
*** Car is Sold *** Thanks for the interest.
Looks like time to sell my 240. I'm asking $9.2k for it. Car is super reliable and an absolute blast to drive. The car has fresh paint but wasn't done that well. I was originally planning on redoing it as I paint cars for a living. Since I'm short on time I have decided to sell it instead. If the car doesn't sell I will entertain parting it out. However I am NOT parting it out at this time. Here is a list of mods and a few photos. Thank you for your interest. Engine: 284WHP/246WTQ S13 redtop SR20DET engine and transmission S15 T28 turbocharger Z32 MAF sensor Tomei 555cc fuel injectors Taka Motorsports braided oil/water lines Apexi PowerFC engine management (tuned by Chuck at AdrenalineXXX, runs PERFECT) Forge 007 blow off valve Greddy front mount intercooler Megan Racing O2 housing TopSpeed 3” stainless downpipe Catco 3” catalytic converter Buddy Club Spec 2 X2 Racing 5-quart oil pan Blacktop oil strainer Greddy oil filter relocation kit w/Aeroquip fittings Koyo aluminum radiator Nismo thermostat Altima electric fans Pivot fan controller GK Tech coolant overflow tank Nismo engine and transmission mounts Walbro fuel pump Drivetrain: Spec stage 1 clutch Driveshaft Shop 1-piece steel driveshaft S15 helical limited slip differential Suspension: Front: Tein camber plates Ground Control coilovers 400 lb/in ERS springs Vorshlag upper spring perches Koni 8610 dampers in Pyeatt housings Koni bumpstops Powertrix tension control rods Stealth Custom T/C bracket brace Energy Suspension steering rack bushings Suspension Techniques 27mm sway bar and bushings Cusco strut tower bar Rear: Tein pillowball upper mounts Ground Control coilovers 300 lb/in ERS springs Vorshlag upper spring perches Koni Eclipse dampers Koni bumpstops Powertrix rear upper control arms Powertrix toe links Powertrix traction links Suspension Techniques 21mm sway bar and bushings Peak Performance urethane subframe bushings RP Sport subframe braces Ebay strut tower bar Brakes: Z32 master cylinder w/S14 reservoir Front: Z32 300ZX 30mm aluminum 4-piston calipers Hawk HPS pads SPL Parts Stainless braided lines Attain 5-lug hubs, ARP extended studs Rear: Z32 300ZX aluminum 2-piston calipers Z32 emergency brake assemblies Z32 2+2 emergency brake cables Carmo e-brake cable adapters Hawk HPS pads SPL Parts Stainless braided lines Z32 5-lug hubs, ARP extended studs Bicho Performance master cylinder stopper Rays Anodized Blue Extended closed-ended lug nuts Body: S13 Silvia front end conversion JDM amber/clear turn signals GTR-style grille Password:JDM Cooling Panel M3-style trunk lip spoiler Dual projector headlights, converted to LHD Interior: Bride Zeta 3 Sport driver seat (also have stock S14 Drivers seat) S14 passenger seat Nardi 330mm Steering Wheel Nismo shift knob Redline Goods leather shift and e-brake boots Stripped door panels Bride upholstered glovebox S14 seat belts AC Autotechnic oil pressure gauge AC Autotechnic boost/vacuum gauge Pivot water/oil temperature readout Greddy Profec B Spec II boost controller JDM speedometer, converted to MPH JDM tachometer, 7500 RPM redline JVC headunit Alpine 6.5” speakers all around Wheels: WedsSport TC105N 17x9 +25 18x9.5 +35 235/40/17 235/40/18 ![]() 240 Comlara shoot-006.jpg by Bodyshopdave, on Flickr ![]() 240 Comlara shoot-013.jpg by Bodyshopdave, on Flickr ![]() 240 Comlara shoot-023.jpg by Bodyshopdave, on Flickr ![]() 240 Comlara shoot-027.jpg by Bodyshopdave, on Flickr ![]() 240 Comlara shoot-028.jpg by Bodyshopdave, on Flickr ![]() 240 Comlara shoot-030.jpg by Bodyshopdave, on Flickr ![]() 240 Comlara shoot-034.jpg by Bodyshopdave, on Flickr Last edited by Bodyshop; 08-26-2012 at 04:09 PM.. Reason: Car is sold |
#8 | |
![]() Join Date: Jan 2009
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
OP, did this car used to have r33 wheels?
#10 |
PMs replied. Sorry for the delay guys. I had a serious buyer that fell through. Im trying to post the new pics from my phone but not having much luck. I do have the dyno sheet and will try to get it posted as well.
