Old 08-10-2012, 05:54 PM   #1
gots13?
gots13? is an unknown quantity at this point
Apexi s1 coilovers only 1k miles must sell.
Hey guys im selling my coilovers set up. It said to say but they cant work with my cup kit so i need to buy some tein flex i paid $1650. I'm willing to loose and sell them for 1200 firm wont go a penny less so don't even try to low ball me .john 626 590 8048...spring Length/Rates: Front- 200mm (8 in.) / 7kgf/mm (392 lbs/in) Rear- 250mm (10 in.) + Helper Spring / 5kgf/mm (280 lbs/in)"A'PEXi proudly introduces the S1 Damper line, developed by a team of A'PEXi engineers and professional racing drivers.
Ride quality and handling performance are not mutually exclusive. Almost all coilover suspension systems are designed for track use, but are not well matched for street use. In fact, most are sprung and dampened improperly for street use, which not only gives a harsh and unpleasurable ride, but also hurts grip performance when the suspension cannot conform to the terrain.
To address this gap, Apex proudly introduces the S1 Damper line, with a specifically selected recipe of spring rates, oil and valving for hi-performance street cars that double as weekend track machines. 100% made in Japan, with precision Japanese components."
Features:
- 20-Way damping adjustment to adapt to a variety of driving conditions.
- Monotube design with 45mm. diameter piston.
- Adjustable lower case design that allows ride height to be adjusted without affecting preload.
- Standardized 65mm. spring allows the use of a wide variety of readily available springs.
- Front strut- type setups include camber adjustment plates that utilize premium quality NMB pillow-ball bearings to minimize deflection, binding, and noise.
- 100% Made in Japan, with precision Japanese components.
This is for s13 only..
gots13? is offline   Reply With Quote
