Old 08-14-2012, 03:33 PM   #1
s13ka24e
s13ka24e's Avatar
s13ka24e is an unknown quantity at this point
s13 Helppppp pleaseee!
I have a 90 240 hatch.
Ok, when i drive on the freeway and im in 5th, sometimes the car just loses power cant rev the engine nothing but the weird thing is the car doesnt turn off all the electronics works when it happens. I just lose power/ throttle responce ,cant rev engine the rpms just slowly drop down the only way i found out how to stop it is to down shift to 4th gear when it happens than it goes back to normal no idea what could be causing it
Help would be awesome thanks <3
s13ka24e is offline   Reply With Quote
Old 08-14-2012, 03:56 PM   #2
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
http://zilvia.net/f/chat/297481-smal...reads-378.html
However, I have this same problem and it's possibly your MAF going out/needs cleaning.
instagram
1on1 is offline   Reply With Quote
Old 08-14-2012, 05:47 PM   #3
s13ka24e
s13ka24e's Avatar
Thanks i think i figured it out though its called a fuel cut
bad fuel pump i guess
Old 08-14-2012, 06:18 PM   #4
MrSanchez925
MrSanchez925 is an unknown quantity at this point
check your TPS.
A failing TPS or even a loose connected one can cause those same problems.
pin point your problem before u start throwing random parts into it hoping it will magically be fixed.
MrSanchez925 is offline   Reply With Quote
Old 08-14-2012, 06:22 PM   #5
s13ka24e
s13ka24e's Avatar
I have pin pointed my problems and i did my research im not throwing any random parts in my car its either the fuel cut problem or the maf is dead. And it's not my tps because i changed it a few weeks ago and it still happened before/after i changed it
Old 08-14-2012, 06:44 PM   #6
Chaluska
Chaluska is an unknown quantity at this point
coil getting weak.... maybe
Chaluska is offline   Reply With Quote
