Old 03-01-2004, 02:05 PM   #1
s13andy
s13andy's Avatar
s13andy is an unknown quantity at this point
Send a message via AIM to s13andy
s13 hacked MAF????``
i read about some guys talking about their hacked MAF sensors, what are you talkin about?
my '91 is not reving past 2400 (its got about 144,000 miles)when it feels like it and its not good, im 99.9 % sure its the MAF but i really dont want to have to buy a new one, is there a way to play with it to make it work? or am i better off getin a decent used one? new one. help meeeeeeeeee
FS/FT 86 Toyota MR2 ~Andy
s13andy is offline   Reply With Quote
Old 03-01-2004, 02:07 PM   #2
nismo2491
nismo2491's Avatar
nismo2491 is making a name for him/her selfnismo2491 is making a name for him/her self
hacking the maf is basically a dsm thing. not too much to hack on the 240sx. it consists of removing material that blocks the airflow.
KEvin
nismo2491 is offline   Reply With Quote
Old 03-01-2004, 02:12 PM   #3
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
get a used one from a junkyard, ebay, or someone from the forum. When someone does an srswap they would have an extra one lying around.. new ones are a few hundred dollars.
Hi
Var is offline   Reply With Quote
Old 03-01-2004, 03:52 PM   #4
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
KEvin
The s13 MAF is all metal, but the S14 MAF is plastic, and can easily be modified the way the DSM folks do it.
sykikchimp is offline   Reply With Quote
Old 03-01-2004, 05:59 PM   #5
Chernobyl
Chernobyl's Avatar
Chernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond repute
Hacking your MAF wont fix it. What is done is you basically take the operational guts out of an S14 MAF and put them in a larger diamter pipe. Because fluid flows slower in a larger diameter pipe, your MAF will output a lower signal than usual, allowing you to use this lower signal to run higher flow rate injectors. That's the jist, at least. There is a bit more to it.
Since you have S13, just go to the junkers and get a new (used) MAF. Shouldn't be more than 20 bucks.
Chernobyl is offline   Reply With Quote
Old 03-01-2004, 07:28 PM   #6
s13andy
s13andy's Avatar
thanks guys, ill be hittin up the junk yard
Old 03-01-2004, 11:22 PM   #7
nismo2491
nismo2491's Avatar
ahhhh so sorry to have misinformated somebody. thanks for the new knowledge.
KEvin
Old 03-03-2004, 12:26 AM   #8
Demik
Demik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of light
Send a message via AIM to Demik
are the NON TURBO and TURBO 300zx maf's the same?????
Demik is offline   Reply With Quote
Old 03-03-2004, 03:36 PM   #9
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
they both use the same MAF
AceInHole is offline   Reply With Quote
Old 03-03-2004, 05:49 PM   #10
Demik
thanks ACE!!!!
