Old 03-03-2004, 04:39 PM   #1
cvilles13
cvilles13 is an unknown quantity at this point
Ka24de motor mounts
Does any one know if cusco sr20det motor mounts will work with my ka24de s13. If not, who makes a good semi-solid ka mount.
1991 s13 5sp
Intake, header, exhaust, test pipe, crank pulley, fal fans, koyo radiator, msd sci ignition, nology hotwires, blaster coil, ngk plugs, msd 8910, 17"cdr-9, nitto, pro-kit springs, kyb's, stb's, optima battery relocated to trunk, Z32 front brake conversion
cvilles13 is offline   Reply With Quote
Old 03-03-2004, 07:02 PM   #2
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
Sure. Just switch them around. Cusco left goes on the right side, and vice versa.
-Jeff
Whatup?
Jeff240sx is offline   Reply With Quote
Old 03-03-2004, 11:59 PM   #3
boosteds14
boosteds14's Avatar
boosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enough
Send a message via AIM to boosteds14
yes the cusco motor mounts are very stiff and they fit the KA no problem
240SXONE
www.240SXMOTORING.com --- One Stop Shop for Your Nissan 240sx
boosteds14 is offline   Reply With Quote
Old 03-04-2004, 03:39 AM   #4
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
Jeff, I never really understood how you could switch from left to right. I have nismo ones and they have an alignment tab on one side, just like stock. How are you supposed to put that on the other side. It wouldn't work. I just kept mine on the side that they say but I'd be willing to switch them if that was what I am supposed to do with my KA.
Flybert is offline   Reply With Quote
Old 03-04-2004, 09:26 AM   #5
Jeff240sx
I hate you too...
Jeff240sx's Avatar
I don't know, since I don't own them. I just know that based on the many people running SR mounts on a KA, the motor-rising problem is mostly taken care of. Search around on FA for a bit and you'll get an answer.
-Jeff
Whatup?
