Old 03-07-2004, 01:57 AM   #1
link240
link240 is an unknown quantity at this point
Post Motor shakes Plus funny idle help me out
After a accident happened i got some questions. Anyone know if front frame damage effect proformance even thought he was hammerd out? After normal driving car ildes really low about 3 hundred, then goes back to 7-6 hundred. Now it shakes alot during idle. Anyone know what it could be plz help me.
link240 is offline   Reply With Quote
Old 03-07-2004, 02:53 AM   #2
DRFT
DRFT is making a name for him/her selfDRFT is making a name for him/her selfDRFT is making a name for him/her self
clean your throttle with carborator cleaner, or clean your maf
and it probably shakes cause of you accident, or just get new motor mounts because yours is probably worn out
ApexNetwork.Net
Sacramento & Norcal Forum
DRFT is offline   Reply With Quote
Old 03-07-2004, 06:22 AM   #3
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
it might be a vaccum leak, something might have cracked in the accident. if you can't see anything, try this little test. turn the car on and let it idle, spray some carb cleaner or starting fluid on the vaccum lines and such. if the engine revs there is a hole there. it'll be hard to tell with the idle so off already, but it's worth a shot.
cdlong is offline   Reply With Quote
Old 03-07-2004, 12:04 PM   #4
aeontony
aeontony is an unknown quantity at this point
Oh..you may want to check if the MAFS is secure on its stand, too. (i.e. the accident hasn't lodged it so it's flopping around).
S14.5 for sale. Must move on with life...=(
http://www.zilvia.net/f/showthread.php?t=56822
Au no wa wakare no hajime...
aeontony is offline   Reply With Quote
Old 03-07-2004, 02:10 PM   #5
FastBack 240
FastBack 240's Avatar
FastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymore
My car did the same at idle until I checked the timing and it was way off. Just fix your timing and I have a strong feeling the stubling and shaking will go away.
FastBack 240 is offline   Reply With Quote
Old 03-10-2004, 01:01 AM   #6
formeRiceR
formeRiceR is an unknown quantity at this point
how do you check timing?
"Street racers don't need girls." -Lonely Driver
Learning about cars one FLAME at a time ... (thanks to TNORD)
formeRiceR is offline   Reply With Quote
Old 03-10-2004, 09:49 AM   #7
FastBack 240
Go to a mechanic. It is adjusting the distributor to correct degree.
Old 03-10-2004, 07:37 PM   #8
epoxy_nc
epoxy_nc is an unknown quantity at this point
i am having this same problem with my SR.
anything else to look for ?
epoxy
sr20det powered '93 coupe se
epoxy_nc is offline   Reply With Quote
