Old 03-09-2004, 08:12 PM   #1
four
four's Avatar
four is an unknown quantity at this point
Send a message via AIM to four
Suggestions? (t28 wastegate issue)
I got a used t28 off a supposed s15 which could only mean that it had to come from an auto S15 or a s14 sr20det. (the wall divider isnt there)
anyway:
the previous owner had it externally wastegated, therefore the internal wastegate door is welded shut. should I:
Get an external wastegate?
Get a new wastegate door and use the internal gate?
Use a dremel to dremel out the weld?
I also forgot to mention that the stock actuator isnt there, but I can get one easily.
thanks in advance
four is offline   Reply With Quote
